Go to Post Travel is a LOT less expensive when you pack the grown ups in the crate. - Rich Kressly [more]
Unread 01-02-2016, 18:40
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
What is this thing?
Does anyone know what this motor is? Does anyone have a datasheet for it?
ID:	19939  Click image for larger version
Unread 01-02-2016, 18:48
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: What is this thing?
Looks like a seat motor.
Unread 01-02-2016, 18:51
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Yep, seat motor, but with lead screw?
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 01-02-2016, 19:41
They had a leadscrew adapter way back in the day. Problem was the durn thing was located a foot away from the motor!
Unread 01-02-2016, 19:48
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Pehaps this-http://files.andymark.com/2014-12-01...le%20drive.pdf
Unread 01-02-2016, 21:21
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Looks like a FIRST Choice item from last year.
461 Westside Boiler Invasion
45 Technokats
Unread 02-02-2016, 08:56
FRC #4206
Thank you all for your responses! I showed that data sheet to the guy who asked me to research it and he jumped and clapped.
So thanks!
Unread 02-02-2016, 10:46
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
As one of the Bosch associates involved in getting the Bosch linear seat motor into the FIRST Choice program for last year, I can testify that the datasheet linked by MoistRobot is in fact the correct one for this motor.
Related links:If you're thinking of using that exact motor on an FRC robot this year, however, you're out of luck; motor legality within FIRST is based on widespread availability (as defined by "lots of them being donated for inclusion in the KOP and/or FIRST Choice"), and we were unable to get enough of them out of our factory to be able to bring them back this year.
EDIT: I stand corrected! If you can get your hands on them, go for it.
For this year, we are currently offering a rotary-output worm drive seat motor that was available in much larger quantities. The 2016 Bosch motor has a normal rotational output instead of the linear output of last year's Bosch motor, but we can bring it back next year as long as our post-season survey shows that teams got good use out of it.
Unread 02-02-2016, 10:55
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Originally Posted by Skywalkar View Post
If you're thinking of using that exact motor on an FRC robot this year, however, you're out of luck; motor legality within FIRST is based on widespread availability (as defined by "lots of them being donated for inclusion in the KOP and FIRST Choice"), and we were unable to get enough of them out of our factory to be able to bring them back this year.
Question, Is the motor commercial available for purchase?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 02-02-2016, 11:36
Ryan_Todd's Avatar
ye of little faith
Unfortunately, no; the reason why we weren't able to place an order for a second year of donations was that the 2015 spindle motor was [EDIT] non-standard and built from the ground up from excess inventory specifically for that purpose. [/EDIT]
Here's the closest motor that I could find out of what we're currently producing right now:
http://www.bosch-ibusiness.com/boaae...57/product/614
It drops the Hall sensor, but the other characteristics and dimensions are quite similar. You should be able to find it from third-party resellers, scrap yards, and even directly from Bosch (see below) since this motor is used in vehicles built on the GM Alpha platform:
https://en.wikipedia.org/wiki/GM_Alpha_platform
While I'm at it, here are a few others like it:
http://www.bosch-ibusiness.com/boaae...%20Spindle/357
The public-facing method for purchasing these motors from Bosch is located here:
http://www.bosch-ibusiness.com/boaae...m?locale=en_GB
I don't personally work in the motors group, however, so there may be easier (or cheaper) ways than what I've found here. Let me contact Kevin (the lead associate in getting these motors available in the first place) and see if he's got any better ideas...
Last edited by Ryan_Todd : 02-02-2016 at 13:50. Reason: Thanks for the corrected info, Kevin!
Unread 02-02-2016, 11:44
Mentor,QCR Planning
Unfortunately, no; the reason why we weren't able to place an order for a second year of donations turned out to be that the 2015 spindle motor was going out of production altogether.
You should be able to find that particular motor from third-party resellers or scrap yards for a while yet, since that motor was most recently used in vehicles built on the GM Alpha platform:
The public-facing method for purchasing these motors is located here:
I'm not personally interested but per the manual this year:
Originally Posted by Game Manual Section 4
Table 4-1 Select Automotive Motors (Window, Door, Windshield Wiper, Seat, Throttle)
are legal and unlimited.
Unread 02-02-2016, 11:49
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
That hasn't been the rule for a couple years. All automotive motors (that fall into the categories in the manual, seat, door, window, etc) are legal motors. So all the old window motors, or motors got through the old scrap yard donation form thing etc, are all legal if they were unmodified prior to this season. At least that is my interpretation of the rules.
Unread 02-02-2016, 12:15
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
kprzewodek is an unknown quantity at this point
Slight correction....this was actually custom made for the KOP in 2015 using existing parts in NA. Due to there not being much positive feedback (or feedback at all) and high cost we decided to discontinue. Of course we want to find what is most useful to teams so remain open to suggestions.
I actually have around 10 left from last year. I can distribute according to interest but sparingly...just ask for what you need at the moment and be considerate that some may want to use on the robot this year. These types of motors are very common in the seat height/tilt adjustment and steering column adjustment functions so scrap yards are a great place to look.
As Ryan said there is a very similar motor offered on GM alpha vehicles which is basically the same. I'm not so familiar with the purchase as needed options since this just started up but can explore that a bit. Typically these parts are built as required so large stock was usually not kept for general public purchase. Will keep you posted as I hear/explore more.
Unread 02-02-2016, 13:49
Ryan_Todd's Avatar
ye of little faith
Wow, did I ever need fact-checking!
Thanks everybody for helping to clear that up; I've [EDITED] both of the above posts to avoid distributing misinformation.
Unread 02-02-2016, 13:56
kprzewodek's Avatar
Usually these motors do have that long adapter in seat height adjustment applications where the longer lead screw is used. That's the main reason we had to make a custom part for last years first choice option.
