Go to Post Please teams I implore you obey the no saving seats rule. Or at least be very friendly in inviting people to sit with you. - IndySam [more]
Unread 01-02-2016, 19:47
Streetbots Streetbots is offline
FRC #4964
Streetbots is an unknown quantity at this point
Starting configuration
Can someone explain the starting configuration, such as the distance from robot to robot? Any visual with measurements is appreciated.
Unread 01-02-2016, 19:56
Re: Starting configuration
Starting Configuration is the way YOUR robot starts the match, irrespective of placement on the field.
--Everything inside the Frame Perimeter
--Everything under the height limit of 54"
What you're looking for is G7.
Originally Posted by THE MANUAL
G7 When placed on the FIELD for a MATCH, each ROBOT must be:
A. in compliance with all ROBOT rules, i.e. has passed Inspection (for exceptions regarding Practice MATCHES, see Section 5 (5.5.2 Eligibility and Inspection)),
B. not in contact with a BOULDER staged on the MIDLINE,
C. the only item left on the FIELD by the DRIVE TEAM,
D. confined to its STARTING CONFIGURATION,
E. fully contained by the opposite half of the FIELD from their TOWER, and
i. breaking the plane of the AUTO LINE, or
ii. inside the COURTYARD, in contact with both the CASTLE WALL and GUARDRAIL.
Only one (1) ROBOT per ALLIANCE, known as the “spy bot,” is allowed to start each MATCH in this position.
See the bold text.
There is no robot-robot distance (other than that the alliances aren't hitting each other).
Unread 01-02-2016, 20:03
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Starting configuration is the static configuration of your robot prior to the start of the match. All of your robot components need to be inside the frame perimeter and below the maximum starting configuration height.
The robot inspection process verifies your robot can meet the starting configuration rules. Before matches, referees will look at your robot to make sure actually are complying with starting configuration rules (nothing sticking out beyond the frame, etc.).
Edit: sniped by EricH! (What he said...)
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 07-02-2016, 13:08
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Lead Software Mentor
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
Send a message via AIM to Sky Captain
For G7Eii: inside the COURTYARD, in contact with both the CASTLE WALL and GUARDRAIL.
Does this mean we can put our robot at a 45 degree angle so that it touches both the wall and guardrail and still avoid breaking this rule?
When in doubt, check the documentation.
Unread 07-02-2016, 14:41
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
It also has to break the vertical plane of the auto line (i.e. Have any part (including bumpers) above it)
Unread 07-02-2016, 15:27
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That's certainly how I read it; you can be square in the corner, or at any oblique angle, as long as you're in contact with both boundaries.
