Go to Post I feel that I learned more last year than any previous year because of the challenges we faced. - paldrid [more]
Unread 01-02-2016, 22:07
Drew_trak's Avatar
Drew_trak Drew_trak is offline
AKA: Drew Petrak
FRC #0599 (Robodox)
Drew_trak is an unknown quantity at this point
Building defenses
Hello, our team is planning on building the defenses this week. Did any of you guys encounter any common problems? Is there anything we should be aware of or look put for?
Thanks for the Help
Unread 01-02-2016, 23:54
snoman's Avatar
snoman snoman is online now
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of light
Re: Building defenses
Pretty straightforward we got all Category B & D made also tower, working on climbing bar and Category A as we speak
Good luck
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 02-02-2016, 05:23
Dibit1010 Dibit1010 is offline
FRC #0587
Dibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond reputeDibit1010 has a reputation beyond repute
When building the rough terrain put at least two screws in each block- also your rough terrain well get super chipped if it's made of wood
Unread 02-02-2016, 06:34
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Make sure you check out team update 4 because there was a change in the original field drawings to the rockwall dimensions. If you're just printing the cut sheets now then you should be good, but I'd still double check it. (I think it's update 4, it might be 3 if it's not in that one.)
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 02-02-2016, 08:12
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
To replicate the metal surface we'll see in actual competition, we covered the top of the moat, rock wall, ramparts, and cheese fries with aluminum flashing. This way we'll see similar traction with the drive train and reflectivity with our sensors.
Hi!
Unread 02-02-2016, 11:17
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Originally Posted by Taylor View Post
cheese fries
Mmmmmm.
