Go to Post There is always more than one way to design something. - Dave Scheck [more]
Unread 01-02-2016, 22:17
avestasticc's Avatar
avestasticc avestasticc is offline
AKA: Avery
FRC #0379 (The RoboCats)
Rookie Year: 2015
avestasticc is an unknown quantity at this point
Raspberry pi and LabVIEW
We are using a servo tracking system on our robot. Since the camera bogs down the rest of the system could we use a raspberry pi just for the camera to run on? Could we still use the regular LabVIEW programming? Also, what model pi could we use? Thanks!
Unread 02-02-2016, 08:41
Re: Raspberry pi and LabVIEW
Introducing another controller into the mix will lighten the CPU usage, but will add communications latency and will add complexity.
Do you know why your CPU is bogged down? Have you tried some simple things to fix it?
Greg McKaskle
Unread 02-02-2016, 13:19
AKA: Avery
Rookie Year: 2015
Nothing else would work on our robot except the camera, but as soon as it was disabled in the code everything worked fine. We aren't sure why this happens and I tried to lower the resolution to see if that would work but so far nothing has.
Unread 02-02-2016, 15:36
If you were to post the code, or even a picture of the vision processing diagram, I might be able to help more.
Greg McKaskle
