Go to Post That is just ridonkulous. - Brandon Holley [more]
Unread 25-01-2016, 09:29
doctorflems doctorflems is offline
FRC #4506 (PioNerds)
Rookie Year: 2015
doctorflems is an unknown quantity at this point
Lightbulb Using the Jetson TK1 with LabView (sort of)
Hello, everyone--
This is my second year in the FRC, and I have been slammed to the top of the programming team by a matter of circumstance. It was originally out of curiosity that I installed LabView on my personal gaming PC (which is a very hardcore budget PC, but that's another topic), and continued noodling around like I had been during the last offseason. At the next team practice, I learned that I was the only team member who had access to a programming platform. I only know LabView, and just enough Arduino C++ to get by.
The arrival of our Jetson TK1 gave us quite the idea: Shouldn't it be possible to program the JTK1 in Java, and have it feed the results of the image processing to the RoboRIO over some form of serial communication?
Good news is, I'm no longer the only one programming, since now we have someone on the Jeston as well.
Unread 25-01-2016, 10:06
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Using the Jetson TK1 with LabView (sort of)
Short answer is yes it is. I recommend the RS-232 connection. I'm also %900 sure someone else here has done this exact thing very successfully. See: http://www.chiefdelphi.com/forums/sh...&highlight=TK1
and: http://www.chiefdelphi.com/forums/sh...&highlight=TK1
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 25-01-2016, 10:12
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Talking Re: Using the Jetson TK1 with LabView (sort of)
Originally Posted by doctorflems View Post
Hello, everyone--
While it would be possible to program some vision code in Java, to utilize the GPU of the Jetson TK1 and all of the opencv customization NVIDIA built into the OpenCVforTegra you would need to use C++.
For communications there are many options.
Originally Posted by marshall View Post
Before you pick one... ask yourself what data you are sending and where, and why you are sending it. Some data that gets sent does not always need to get sent...
We used NetworkTables last year but we've found it to be slow for our purposes this year so we are investigating alternatives.
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
Unread 01-02-2016, 23:17
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
I've used udp. works a treat
Unread 08-02-2016, 19:28
Juxttech Juxttech is offline
FRC #4918
Juxttech is an unknown quantity at this point
Could you possibly share your UDP code? That's what I'm trying to use and I'm struggling with it
