Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
  #31   Spotlight this post!
Unread 01-02-2016, 12:28
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Re: pic: Are these legal?
What about just painting the connector? Blue, purple, green, whatever if that is important to you?
success is not hocus posus, it's focus focus
  #32   Spotlight this post!
Unread 01-02-2016, 12:42
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I think R66 would apply and make painting the connector illegal. At least that is my take on the rules.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #33   Spotlight this post!
Unread 01-02-2016, 20:43
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
R66 says nothing about the wires or connectors attached to the battery. It says you can't change or modify the battery (among other things).
I don't see an issue with modifying the connector to mate with another connector. This isn't reducing it's protection from a short or its current carrying capacity of the connector itself. It's like saying a car isn't safe in a crash because you took the dice off the mirror. They aren't integral to the function of the device.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
  #34   Spotlight this post!
Unread 01-02-2016, 21:06
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Somebody correct me if I'm wrong, but I could have sworn it was legal to make an adapter that goes from, say, a red SB50 to a SB100 and have it be part of your robot. Could the same thing work for blue to red SB50s, or am I mistaken?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
  #35   Spotlight this post!
Unread 02-02-2016, 07:42
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Please see R31...
In part it reads:
"Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.),"
As to modifying the SB50/120 connectors, the intent of R66 is to prevent teams from modifying electrical items in such a way that would cause a safety issue. Removing anything from a high current electrical connector may affect the safe use of such an item. R9 is also a little more pertinent to this question. The SB connectors are tested by UL for specified current and voltage without parts removed.
And I'm sure they are tested without being painted or modified on the external surfaces of the connector as well. What's to prevent a team from wrapping a 1 1/2 inches of Viton around the connectors and 4 inches down the wire? Is that legal? My thought process tells me it is acting as insulting device and not allowing heat to be dissipated and possibly causing a meltdown.
The intent of R66 is to prevent the intentional modification of electrical components to maintain some reasonable level of safety. I am all for innovation, but there are some guidelines and rules we all need to stay within.
Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
  #36   Spotlight this post!
Unread 02-02-2016, 08:01
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
"The SB50 connector series is keyed by color."
"Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect."
It will be either a black or gray connector and it won't fit the blue one. This would be the biggest reason to not use the blue connector.
The color keyed SB50's is a nice feature if you know you'll never need to mate with a different color. We did a project with them, color coded cause it was cool and then got burned when we couldn't swap around. Decided to make "color adapters" and then decided to go black/gray all around with a strip of colored tape on the connector and cable.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
