Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 02-02-2016, 09:17
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Playing well with others while scaling the tower
I haven't seen this issue raised by anyone else, though I admit I haven't been monitoring CD this year as closely as I have in the past. It seems like teams are leaving their climbing mechanisms for development later in the season, and may not have noticed an issue which may affect your drive drain design.
I wanted to point out something important about geometric constraints when scaling the tower. If your robot exceeds 24 inches wide, including the bumpers, and you plan to scale with your bumpers sliding up the tower, there are a couple unpleasant consequences.
1) If you scale adjacent to the wall, the wall will push you off center. This means you might only be able to scale from the center face of the tower.
2) If you scale from the center face of the tower, and you overhang to the sides, you may interfere with adjacent robots. If they get there first, you may be blocked from scaling. If you get there first, and you only scale to the minimum height, you may block your alliance members from scaling.
Possible solutions:
1) Have a very narrow robot.
2) If your robot is wide, scale first, and raise yourself 5" MINIMUM higher than necessary, to allow your neighbor to scale next to you.
3) Plan to be the only robot on your alliance to scale. This will limit your chances to be on a winning alliance.
4) Chamfer the side of your robot that contacts the tower such that you play nice with others. (see attached figure)
5) Use some other robot/scaling geometry that doesn't have this issue.
I'm publicizing this issue because we want to be on alliances with multiple climbing robots, and putting it out there makes it more likely this will happen.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 02-02-2016, 09:36
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: Playing well with others while scaling the tower
This would have been a great PSA in week one. Frames are likely done by now, we'll see how this plays out.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 02-02-2016, 09:40
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
+1, but climbing heights can still likely be adjusted.
Unread 02-02-2016, 09:52
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Don't I know it. I love discovering these little traps the game design committee has laid for us when it's too late for most teams to do anything about it.
Raising yourself higher is a pretty viable option, though. As is pushing yourself away from the wall (after hooking in) so your bumpers stay on your side of the divider.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 02-02-2016, 09:58
wendells's Avatar
wendells wendells is offline
FRC #2185 (RAMAZOIDZ)
wendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to allwendells is a name known to all
Todd.......you deserve a MEDAL......
Unread 02-02-2016, 10:22
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
This discussion has been brought up similarly at least twice.
http://www.chiefdelphi.com/media/photos/42647
http://www.chiefdelphi.com/media/photos/42667
Still it's important to make sure everyone has considered it. I'm 100% sure any team could climb next to my team thanks to some design choices we made very early on.
John Fogarty
Unread 02-02-2016, 10:32
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
Cool Re: Playing well with others while scaling the tower
We are currently work on building our climber and brought this at a meeting the other night. We are planning for two different heights when we scale. Left and Right side when scaling will be right above the line we have to cross. If we go center will make sure where first to scale and go higher than we would on the left or right side. This is what our plan is as of now but it could always change.
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Unread 02-02-2016, 10:37
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
The robot that can scale the highest on your alliance scales 1st and in the middle location. Then the 2 robots on the sides can scale anytime after. No issue.
2012-2016 Wave Robotics Team 2826
Unread 02-02-2016, 11:00
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Yep. I definitely should have been monitoring CD more closely.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 02-02-2016, 11:17
laplacier's Avatar
laplacier laplacier is offline
FRC #1287 (Aluminum Assault)
Rookie Year: 2015
laplacier is an unknown quantity at this point
I think the key will be for the quickest scaler to be in the center, regardless of chassis size. The sooner the middle is out of the way the faster the rest can start their climb and there will be more than enough room on the left and right for their chassis (no middle robot to contact!)
Unread 02-02-2016, 13:21
philso philso is offline
FRC #2587
I recall the team member doing the motor calculations for the scaling winch saying he used a time of 15 seconds. It occurred to me the other day that a faster time so you can get out of your alliance mates way would be an advantage.
Unread 02-02-2016, 14:00
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
I think it would be prudent for teams to really consider this.
I know our team has chosen to hang very high so that other teams can get underneath us if necessary. We have also added extra power to our climbing mechanism in order to lift in just 2-3 seconds so we can get up higher and faster to allow other robots to climb underneath us.
We were lucky enough to identify this Key Performance Parameter early in the design process.
We hope to design so that our alliance can be successful
We will also be able to hang at a lower height if necessary to help the group hang.
Many teams seem to look at hanging as only a difference of 10 from sitting. I think the further we progress in the season, three hangers will be necessary.
From an alliance viewpoint... it is a 30 point swing.
good luck and see you on the field and at the tower!!
Unread 02-02-2016, 14:28
Jared Russell's Avatar
Taking a year (mostly) off
How often did 3 robots on an alliance all hang in 2010?
That was a much simpler game (fewer things to do/less tradeoffs to make) and hanging/suspending was the single most valuable robot action, points wise. The rules on robot expansion were more lenient (84" diameter cylinder during the endgame), there were 4 sides/corners for teams to find space, and there were multiple options for hanging (vertical or horizontal bars).
I would love to see all 3 robots scale the tower regularly, but I think it will fall into the "there's a Chief Delphi post every time it happens" category of rarity.
Unread 02-02-2016, 15:11
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
In 2010, there weren't nearly as many teams as we have now, there were not nearly as many gearbox/motor/mechanism COTS options available, and there were not as many web based/otherwise easily accessible design and knowledge resources. FIRST is growing, and with it the average quality of teams. That's the nature, and arguably the goal, of any competition; improvement.
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 02-02-2016, 20:39
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
All of these points are legit. This year will be more like 2013, the year that no one climbed above the first rung.
Remember why you're doing this.
