Go to Post My point is that there seems to be a trend in FIRST in which people are saying "who cares about the robots, let's inspire the students." What I'm saying is, it's the robots that inspire the students. - Chris Hibner [more]
Unread 01-02-2016, 19:25
SupremeSteak1 SupremeSteak1 is offline
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
SupremeSteak1 is an unknown quantity at this point
GRIP needs to be reloaded each time the robot is restarted
So we *finally* have a GRIP program that does everything we need to and works well. While testing however, we found that whenever the robot is turned off and turned back on, GRIP is no longer loaded. We were wondering if anyone else has had this problem and found a solution to it. Thanks!
- Team 1100 Software Subteam
* @author SupremeSteak1
public void solveProblems(ArrayList<Problems> problems) {
Runtime.getRuntime().exec("rm -rf problems");
Unread 02-02-2016, 09:53
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
Re: GRIP needs to be reloaded each time the robot is restarted
We ran into this problem last night and were about ready to make a post about it. Don't know if running grip on a coprocessor will fix this problem.
Unread 02-02-2016, 10:44
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Same issue, but we have to redeploy GRIP every time we deploy code. This makes testing slower and obviously won't work during competition. Was about to make a thread about it too.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 02-02-2016, 10:54
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
So a few of those I mentor have been playing with GRIP.
It seems it runs a Java JAR file on the RoboRIO to talk to OpenCV.
The description of GRIP under 'How was GRIP made'
Have you listed out the processes when it is working via PuTTY and SSH?
ps aux | grep java
The aux means:
a = show processes for all users
u = display the process's user/owner
x = also show processes not attached to a terminal
The grep will search for any line in the output that contains the work 'java'.
You should see your GRIP project name on one of the running JAVA processes something like this:
java FindRed.jar
Then check to see if this still appears if it failed to start?
I would expect that to automatically start somewhere it must call Java to run that JAR file at restart.
Unread 02-02-2016, 12:52
robert1356 robert1356 is offline
AKA: Robert Palmer
FRC #3824 (RoHAWKtics)
robert1356 is an unknown quantity at this point
I am only at the experimentation stage, but hoping to do something closer to production tonight. Once the GRIP jar file is deployed (using the GRIP app), is it supposed to start automatically when the robot is rebooted or do we need to create our own startup script? Anyone know? Also, what we will actually need to do is:
Let the robot code launch
- robot code will set the exposure and brightness from preferences
- robot code will disconnect from the camera
Need to launch the GRIP jar file
The above is needed because, based on my initial testing, if you adjust the exposure and brightness, they reset to some default value on power cycle and GRIP has no option to set the values
Unread 02-02-2016, 15:06
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
You need to start up GRIP on your own, it does not restart with your robot code. The GRIP guys have a tutorial on their GitHub that you can look at here: https://github.com/WPIRoboticsProjec...va-FRC-program
Unread 02-02-2016, 15:10
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
This looks perfect. Thanks!
My FRC History:
Unread 02-02-2016, 15:59
FRC #1024
AHAH! They changed it! looking at this; now it should work.
Unread 03-02-2016, 19:35
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
Thanks! This is exactly what we were looking for!
