Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
Unread 02-02-2016, 16:51
2386programming 2386programming is offline
FRC #2386 (Trojans)
2386programming is an unknown quantity at this point
Re: PID While Loop
I'll try putting the Pid in the other loop. What is being done is we have made an algorithm to find out how far back or forward we need to move to be in line with the lower goal. The PID is to have the robot move to the proper setpoint.
Unread 05-02-2016, 08:48
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: PID While Loop
So a few problems here.
A while loop with no time constraint is asking for trouble. It'll eat up your CPU resources running as fast as possible while not maintaining a constant delta time between calls. That will make it untunable since the dT between calls is never the same. That's my biggest
If you want to terminate a separate running while loop, you can use Notifiers. Definitely look at some example code in the LabVIEW help. If you use Obtain Notifier in code that you call often, you need to call Release Notifier, or else it will eat up all your RAM over time. Ask me how I know...
But, as aeastet, you typically want to keep your PID running at all times. Perhaps put it in a while loop in Period Tasks that runs every 50ms? You can share the set-point using global variables or notifiers.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 06-02-2016, 23:43
Re: PID While Loop
It looks like you want to share data constantly between the two loops by running wires between them. That's not how LabVIEW works -- a loop doesn't produce an output until it has finished running. You need to put everything in the same loop, or you can share data using variables (local or global) or queues or some other mechanism.
