Go to Post If the refs are not calling something that you think should be called, you have to adjust your play style to deal with it. - Rob [more]
View Poll Results: How many balls will you shoot during autonomous at your first event?
0 45 13.55%
1 219 65.96%
2 46 13.86%
More than 2 22 6.63%
Voters: 332. You may not vote on this poll
  #31   Spotlight this post!
Unread 02-02-2016, 15:02
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: How many balls will you shoot during autonomous?
Originally Posted by Kevin Sevcik View Post
I think you mean if you can manage to put two additional boulders in the tower and CHALLENGE in the time it would take you to scale. Since you'd be foolish to miss the capture bonus and CHALLENGING, while trivial, does take a finite amount of time to execute.
I think I said that in the message you quoted.
  #32   Spotlight this post!
Unread 02-02-2016, 15:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Originally Posted by notmattlythgoe View Post
I think actually scoring a ball in auto will be a commendable action.
Single-ball seems straightfoward for a consistent shooter. The audience and opponents will inevitably help out:
Category A: Portcullis may be slow, but easy to get consistent. Given the width of the defense and the width of typical robots, each bot on an alliance would be on its own (unlike category C). Cheval De Frise will be faster, but it's easy for the robot to come off at an angle and become misaligned.
Category B: Single ball shooters will laugh when the moat is put in front of them and cry when the ramparts are put in front of them.
Category C: They're slow to get through no matter what, but patience with autonomous mechanisms will inevitably show the way. Also don't rule out a team bringing one down for the partner in autonomous, then following that partner through. It will be fun to watch this happen.
Category D: Rock Wall has a bit of indeterminate behavior depending on high-siding of the drive train, but should be consistent if the drivers are precise in robot orientation when they set the bot down. Rough terrain is easy once a good path is figured out, but that also requires proper setup of the robot.
GitHub
  #33   Spotlight this post!
Unread 02-02-2016, 15:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Chris is me View Post
Getting to those specific spots without losing position accuracy while crossing the various defenses is an immense challenge that teams seem to be consistently underestimating.
Quoted for truth. The most improbable part of a 2-ball auto is the part where you cross a defense, then cross back and find a gray ball on a gray carpet in a specific location. Without crossing the midline, if you're grabbing a midline boulder.
  #34   Spotlight this post!
Unread 02-02-2016, 15:15
Turing'sEgo Turing'sEgo is offline
Turing'sEgo can only hope to improve
Is anyone considering scoring their teammate's boulder in autonomous (given that they aren't planning on scoring it)? It seems that this is a safer alternative than getting a boulder from the center and risking G13, and it will accrue the same amount of points.
  #35   Spotlight this post!
Unread 02-02-2016, 15:21
philso philso is offline
FRC #2587
And then cross a DEFENSE a third time. That's three opportunities to Tortuga...
This would probably be a safer option up till Division Eliminations at Championship.
  #36   Spotlight this post!
Unread 02-02-2016, 15:35
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
A one boulder score from spy bot will be common by week 1
A one boulder score from low bar bot will be common by week 1
A two boulder score from teams that dialogue with each other will occur by week 3. Especially from those with rear ball intakes working with those who have front ball intakes. But it will be a feat claimed by advnced programming and sensors.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
  #37   Spotlight this post!
Unread 02-02-2016, 16:16
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I think an alliance surpassing a 30 point auto at any district in our region is literally not going to have a chance in hell. When I meant commendable, I meant top 1% of teams.
  #38   Spotlight this post!
Unread 02-02-2016, 16:23
JesseK's Avatar
FRC #1885 (ILITE)
Such a pessimist
GitHub
  #39   Spotlight this post!
Unread 02-02-2016, 18:11
President, VEX Robotics, Inc.
The 3 Boulder Auton is the Lochness Monster of 2016. Many people will claim it, but no one will actually achieve it.
Now, I have been wrong before....
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #40   Spotlight this post!
Unread 02-02-2016, 18:17
I could forsee this happening: Robot A goes under the low bar and scores in the high goal. Robot B, discharges it's bot gently on the floor and moves away. Robot A goes back, picks it up, scores it. Robot C is the spy bot and also gently puts its ball on the ground in a convenient place. Robot A picks that ball up (as it's right next to it), and score it too.
Even that would be a time crunch.
  #41   Spotlight this post!
Unread 02-02-2016, 19:11
We managed that kind of autonomous, just, with the Wired Cats (2415) in 2012. They had a good shooter and 270 degree intake. All that 57 and 3997 had to do was feed them balls from the back and side at the right times to avoid controlling >3. And in our case, drive forward and tip the bridge to steal those balls. We JUST managed to get this programmed and tested over lunch. And 15 seconds was just about enough time to get it done. Grainy video evidence here. So a successful 3 robot rube-goldberg auton in which all of the robots started perfectly positioned and none of the robots moved before the ball hand-off. And yes, it was 6 shots instead of 3, which would be slightly more time consuming. But still. 3 robots perfectly positioned, not moving.
But your thing? Yeah, I can see whipping that autonomous ballet out over lunch. I can't wait for the grainy video evidence for that one.
  #42   Spotlight this post!
Unread 04-02-2016, 23:04
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to behold
I don't think that three-ball strategy would be possible for almost all robots, as it would require multiple precise turns to intake the different balls and score (unless you have a two-sided intake ), which would be nearly impossible without going under the low bar, and even then it would be difficult. I almost think that two midline balls would be easier to intake and score for most teams than that. The sheer amount of variability and the amount of work to program that routine would not be worth the extra 10 points compared to a two-ball. In some matches, your alliance partners may even be able to score one ball, easily making up the difference.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
  #43   Spotlight this post!
Unread 05-02-2016, 02:39
alexpell00 alexpell00 is offline
FRC #2972
alexpell00 is an unknown quantity at this point
this is a little off topic, but wouldn't you get the same number of point by crossing and extra defense as scoring a second ball?
  #44   Spotlight this post!
Unread 05-02-2016, 07:11
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
You can only get points for crossing a single defense in auto. Any additional defenses that you cross grant no points and does not it reduce it's strength.
  #45   Spotlight this post!
Unread 05-02-2016, 11:33
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
Personally, I believe that scoring two balls in autonomous will be unlikely for the majority of the competition season. It will more than likely not occur for the first few weeks and may become rare later.
One, you would somehow have to have a robot to retrieve the ball from the Midline without incurring a G13 infraction. This is possible to do, however extremely unlikely. After you score the first boulder, you will have to traverse a defense for the second time, which increases your chances of not lining up for the ball properly. (This will depend on your sensors for getting the ball.)
Two, consider other robots in autonomous. Your robot would have to avoid colliding with other robots, which would ruin both your autos. How do you plan on preventing his? (At least in Quals, I see preventing it very difficult; in Elims it could be possible do to better strategy and general better robots.)
Third, for a team considering picking up a boulder that an alliance member dropped, how do you plan on coordinating this? The alliance partner would have drop it roughly in the same spot, and it's possible that the boulder will roll away from the intended area. As well, it's possible that they may collide. (Possible in Elims, however I see it as very unlikely.)
tl;dr Shooting two (or even more) boulders will be very unlikely, and difficult, however possible and the best teams will be able to surpass the challenge.
