Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 02-02-2016, 19:57
SwissArmy4057 SwissArmy4057 is offline
FRC #4057
SwissArmy4057 is an unknown quantity at this point
OM5P-AN and RoboRio communctication problem
Every time we start our robot, the RoboRio fails to establish an ethernet link to the wireless router. Pressing the "reset" button on the RoboRio brings the link up with no issues. The RoboRio is connected to the 802.11af port on the router, and connecting a laptop to the RoboRio works as well. I'm not sure if it's a bug in the firmware we flashed, or whether the RoboRio NIC itself is having an issue with the router.
If I were to take a guess, I would say the router isn't initializing fast enough and the RoboRio is shutting down the ethernet port when the ACK requests time out.
We've flashed the RoboRio with the 2016 firmware, as well as flashed and configured the OM5P-AN for our team number.
Unread 02-02-2016, 21:15
Re: OM5P-AN and RoboRio communctication problem
Move the roboRIO Ethernet connector to the POE port on the OpenMesh, the one closest to the power connector.
A small number of radios seem to have an issue with connecting immediately to the roboRIO through the 802 port.
Unread 02-02-2016, 21:21
FRC #4057
Lightbulb Re: OM5P-AN and RoboRio communctication problem
Thanks - this resolved the issue. I'm not sure why using the af port causes an issue.
