Go to Post I had so much to say but I dont know how to get it accross -- but to all of you that we were involved with this weekend, thankyou for everything -- we're changing lives, and we truly are moving mountains, in more ways than one. - Jacqui Sutton [more]
View Poll Results: What will be the ratio of successful 2-ball autos to G13 infractions?
>8 times as many G13 infractions as successful 2-ball autos. 28 25.69%
8 times as many G13 infractions as successful 2-ball autos. 5 4.59%
4 times as many G13 infractions as successful 2-ball autos. 14 12.84%
Twice as many G13 infractions as successful 2-ball autos. 20 18.35%
Equally many G13 infractions and successful 2-ball autos. 22 20.18%
Twice as many successful 2-ball autos as G13 infractions. 6 5.50%
4 times as many successful 2-ball autos as G13 infractions. 3 2.75%
8 times as many successful 2-ball autos as G13 infractions. 3 2.75%
16 times as many successful 2-ball autos as G13 infractions. 1 0.92%
32 times as many successful 2-ball autos as G13 infractions. 1 0.92%
>32 times as many successful 2-ball autos as G13 infractions. 6 5.50%
Voters: 109. You may not vote on this poll
Unread 02-02-2016, 18:07
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: ratio of 2-ball autos to G13 infractions
Originally Posted by Turing'sEgo View Post
It is a harder task, but is it harder than picking up from the middle of the field without being called for G13? You get your schedule ahead of time, you do some pre scouting and ask a team that isn't planning on scoring their boulder in autonomous to gently place it on the ground for you. It takes coordination, which may be difficult, but it is a safer alternative and in my opinion easier to execute than picking up from the mid line as it doesn't require your autonomous to be perfect down to centimetres.
We would MUCH rather pick up from the mid-line.... It may be a bit tricky, but the boulders are in very predictable locations - which can be programmed from our shop... Coordinating such a thing with another robot would require specialization every match we attempt it (generally there would not be time) and runs the risk of mistakes. (We make plenty of mistakes with our own robot, we don't need to compound them with another team's errors.)
Unread 02-02-2016, 18:21
Turing'sEgo Turing'sEgo is offline
Turing'sEgo can only hope to improve
Yes, it requires both robots to work well, but it is doable.
Imagine this scenario: You just picked your alliance for elims. You have a lunch break before the matches start. It isn't inconceivable to get this working in that hour if the robot doing the scoring has a way of tracking balls, knowing where it is on the field, and preferably some sort of waypoint based trajectory planner to put everything together so you don't have to guess and check every step of the way.
Unread 02-02-2016, 18:47
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by MaGiC_PiKaChU View Post
I'm starting to think getting a G13 might be worth it.
single ball + cross = 20 points
2 balls + cross + g13 = 25 points (30 to you and 5 to the opponents)
The last boulder would give only a 5 point advantage, but you get to weaken the tower by 1 more boulder every match.
Until you start racking up yellow cards for repeated infractions of the rules.
(since 2004)
Unread 02-02-2016, 19:15
Or... You can simply pick an alliance member who can score its own boulder while crossing a defense.....
Unread 02-02-2016, 21:05
I suspect there will be several regionals where it is impossible to draft an alliance where all 3 robots can cross a defense and score in the high goal.
Unread 02-02-2016, 22:28
Joenac says there will not be a single regional/district where an elimination alliance has 3 robots that cross a defence and score in the high goal. Joenac is considering expanding that to every event except IRI.
Unread 03-02-2016, 01:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
An auto ball is worth 10 points, and a G13 foul is worth -5 points. If teams play smart, there will be fewer than twice as many G13s as second boulders scored. I expect the actual ratio to be worse than this; teams tend to be optimistic.
