Go to Post its pretty great when non FIRST friends go into your purse for chapstick or something and find a spike... - anna~marie [more]
Unread 15-12-2015, 06:44
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: FRC shifting gears
Originally Posted by Lil' Lavery View Post
While you're correct that devices like these are pneumatic cylinders, the portion of the cylinder applying a force to shift gears would be a piston. What he said is not incorrect.
Just because he isn't incorrect doesn't mean that he's right. This is a great opportunity to stress the proper terminology for the assembly, and not use the term for a single component within.
Just like I don't claim to drive my engine up to the store... truck is a lot more appropriate.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 15-12-2015, 06:57
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Actually the part applying the force is a rod or shaft. The rod is attached to a piston.
Unread 03-02-2016, 03:14
Bluman56's Avatar
Bluman56 Bluman56 is online now
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
With the update to the servo rules this season, is there any change in the viability of using a servo to shift? Thinking of using a SonicShifter as a winch with about 20 lbs of force from surgical tubing when retracted. Don't know if it would be possible to shift with a 10-12W servo in that case.
Would appreciate help. Thanks.
P.S. For those unaware, servos are now limited to the current put out by the 6V rail on the RoboRio instead of a strict Watt requirement as in previous years.
Unread 03-02-2016, 10:48
pfreivald's Avatar
AKA: Patrick Freivald
This "IACNAP Campaign" is pretty annoying.
Linguistically, language evolves and usage is king, so what you want words to mean (and/or what you were taught that they mean, and/or what they originally meant (assuming you can even chase down the etymology to verify)) has no bearing whatsoever on what they currently mean. There is value in specificity, but there's also value in not "correcting" people when they're using terminology understood by everyone in the conversation.
To whit, McMaster-Carr redirects searches for "pneumatic pistons" to their catalog page for "pneumatic cylinders."
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 03-02-2016, 15:48
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
I believe I saw in the Q&A that automotive motors like window motors but more importantly door lock actuators are legal. A door lock actuator could be a dandy device for shifting.
Unread 03-02-2016, 16:03
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Couldn't be said the part applying the force is the air? Clearly you don't have a force until you start having a differential pressure.
Unread 03-02-2016, 16:08
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
That is because McMaster-Carr is more interested in selling stuff that what you call it. They should get an award for the best web based catalog ever.
Or the difference between an engineer and smart engineer.
Unread 03-02-2016, 16:24
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The piston rod is transferring force from the piston head to the shifting mechanism.
Unread 03-02-2016, 17:57
Bluman56's Avatar
AKA: Nikita
FRC #2579
I like that the actuation is linear in door lock motors but from the specs that I've seen (hard to find specs on them for some reason) it looks like they won't be enough. Maybe I haven't looked hard enough but the most I've found was capable of 8lbs of force... :/
Unread 03-02-2016, 20:47
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
8 pounds is quite a bit of force. I'll bet it's good enough as long as you weren't shifting under full load. If your robot didn't have a pneumatics system for other things, it would be a shame to pay that pneumatics weight tax just for those little cylinders.
This one does 10 pounds.
Unread 03-02-2016, 20:51
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
By the way, here's the Q&A that makes door lock actuators legal for the first time ever:
642 Q. Does an actuator with an included motor sold as a "door lock actuator" meet the definition of "Select Automotive Motors" per R29 (sample: http://www.amazon.com/dp/B0088YE6YQ/)?
A. Yes. As per the answer to Q626 , the intent of "Select Automotive Motors" is to limit the selection criteria of automotive motors to those specifically listed in the parenthesis that immediately follows. "Door" motors are listed, and a motor sold as a "Door Lock Actuator" does fall under that category.
Unread 15-02-2016, 18:23
REDBARON's Avatar
REDBARON REDBARON is offline
AKA: Jack
FRC #3556 (Get Smart)
Rookie Year: 2015
REDBARON is an unknown quantity at this point
Our team chose to use servos with the Andymark sonic shifters however now we are looking into using pneumatic cylinders, however we'd also like to avoid adding another system if possible. Has anyone successfully or otherwise used door lock actuators such as this to shift?
Unread 15-02-2016, 19:04
brianbond's Avatar
brianbond brianbond is offline
Head Coach
AKA: Brian
FRC #5102 (The Underbots)
brianbond has a spectacular aura aboutbrianbond has a spectacular aura about
Hands down pneumatics, you can not beat the snappy action of a pneumatic cylinder in this application.
2014 5102 - Head Coach
- Highest Rookie Seed - Central Valley Regional
"Invent Your Future"
2014 Robot Inspector
-CVR, SVR, Champs
2013 3512 - Team Captain
- Regional Finalist - Los Angeles
- Excellence In Engineering
2012 3512 - Mechanical Lead
- Regional Winners - Los Angeles
2011 3512 - Drive Team (Driver)
- Rookie Highest Seed
- Rookie Inspiration Award
Unread 15-02-2016, 21:45
This might be the first year such automotive "door motor" devices are legal. You're breaking new ground here. I think it's a great idea, and if you make it work well you'll probably want to talk to AndyMark about how you mounted things.
Unread 16-02-2016, 02:16
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
I second the pancake pneumatic cylinder from Vexpro. We use it with the 2 CIM ball shifter and it works great.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
