Re: Labview and pneumatics
You should only have one setter in any system. Any more is asking for trouble. |
Yes the motor is only in Periodic Vi
Did you disable the safety config?
The Safety neutralizes the PWM outputs if the motor setting isn't adjusted at least every 100ms.
See where the Safety is enabled in Begin.vi It needs to be either Disabled in Begin.vi (just change the input) or Disabled at the beginning of the sequence and re-enabled as the last step of the sequence. The same thing holds true for handling motors in Autonomous. Last edited by Mark McLeod : 03-02-2016 at 11:32. |
