Go to Post DONT USE ROBOTS FOR EVIL!!! - Cooley744 [more]
Unread 03-02-2016, 11:13
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
Re: Glue shaft on back case of CIM motor
If you are looking for an encoder directly attached to the CIM motor I would recommend AndyMark CIMcoder but it is out of stock for another 2 days, I would talk to your team to see if this would work for you, it sounds more like what you should do if you want to be safe on inspection rules instead of using glue to attach an encoder which could move
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
