Go to Post For FIRST robots, the phenomena listed above just do not apply. - Paul Copioli [more]
Unread 03-02-2016, 11:46
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Re: Cim mounting Legal
Originally Posted by FrankJ View Post
Keep in mind the blue boxes are amplifications and not actually the rule. Those bolts hold the motor together. While I agree that it can be done safely, it pretty clearly is a modification.
Keep in mind those bolts are probably metric. In either case long small diameter bolts aren't standard stock. Without knowing the strength/grade of the original, how do you know your bolt is stronger? More importantly how would the inspector?
While this is the sort of question the Q&A punts on, If I where going to it, I would ask the question
that is a good point on how would the inspector know. We are going to post a Q and A question so if we find anything we will let you know.
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
