Go to Post A drag racer can have all the output torque in the world, but it does no good on ice. - Paul Copioli [more]
Unread 02-03-2016, 11:50 AM
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Cim mounting Legal
If you can mount it from the back, you can mount it from the front, so why not just do that?
Unread 02-03-2016, 11:54 AM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
we have made a ball shooter that has the motor inside the wheel. So that the end is just sticking out. We have another method to mount to the back however this method packages the best.
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 02-03-2016, 12:00 PM
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Changing the housing bolts is not the same as changing the mounting bracket.
It could be easily argued that the back housing is not intended to be used as a mounting bracket, and thus does not have the structural strength the front may have (which is intended to be a mounting point).
Unread 02-03-2016, 06:52 PM
philso philso is offline
FRC #2587
Any side forces on the shaft will be applied at the front end of the motor, by definition. Securing the motor by the front end will allow the mounting system to resist these side forces better than securing the motor by the rear end. Another way of looking at it is that the lever from where the forces are applied on the shaft is very short if the motor is secured at the front. If the motor is secured at the rear, the same force has a much longer lever to cause the body of the motor to deflect. This could result in your pinion gear not meshing. You may get more vibration, especially under load. The higher torque on the two mounting screws at the back could cause the rear plate of the motor or the mounting plate to deform.
