Go to Post My grades were horrid when I started, but thanks to the mentors and other students, I'm now a straight-A student. - Bax2996 [more]
Unread 03-02-2016, 12:39
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: Lidar-Lite Help Please
Originally Posted by Bpk9p4 View Post
any chance you could post a wiring diagram of how you had it wired?
Lidar Lite Pinout is on page 8 of this datasheet: http://www.robotshop.com/media/files...32i500s011.pdf
RoboRio onboard I2C pinout is displayed on the silkscreen of the robot itself.
Simply connect RoboRio -> Lidar Lite:
GND -> Signal/Power Ground
3.3V -> POWER_IN
SCL -> I2C Clock (SCL)
SDA -> I2C Data (SDA)
My V1 sensor worked fine w/the 3.3V power pin from the RoboRIO onboard I2C connector - but you could provide it 5V power instead from one of the 5V RoboRio power rails (or the VRM) and that should work too.
Unread 03-02-2016, 13:13
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
thanks. Some people were saying you need a pull up resist to get it to work. Sounds like you got it to work without one?
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 03-02-2016, 13:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
The roboRIO has 2.2k pull-up resistors on the I2C pins as mentioned on page 15 of the User Manual.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 06-02-2016, 09:47
khannasusa khannasusa is offline
FRC #5190
khannasusa is an unknown quantity at this point
Hi All
Thanks for all your posts and replies. Here is the final update from our experiments -
we looked at the example from Marvin T MARS Team 2614. Thanks "sraque".
There are Lidar Open and read VIs and they work as-is. Also we have our Lidar connected to I2C on NavX via MXP ports on roborio
I have attached 2 images for open and read snippets from our Begin.vi and Lidar controller VIs.
--sk
Unread 06-02-2016, 11:17
Bpk9p4's Avatar
FRC #1756
Looks like you forgot to post the begin. Could you post it
Unread 07-02-2016, 08:53
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Originally Posted by khannasusa View Post
Hi All
--sk
You are welcome. I could not figure out from your post if it is now working or not. If not, connect to the main roborio i2c port, not MXP. From last year, there were issues with the MXP i2c port. They may have been fixed this year, but I do not know.
Unread 09-02-2016, 00:54
Bpk9p4's Avatar
FRC #1756
I have tried both of your code and i keep getting the same error saying
<b>Complete call chain:</b>
i2clib_writeread.vi
WPI_I2CRead.vi
Lidar Read.vi
Simple Digital Output.vi
ERROR -1 i2clib_write.vi<ERR>
Device or resource busy
i2clib_write.vi
WPI_I2CWrite.vi
Lidar Read.vi
ERROR -1 i2clib_writeread.vi<ERR>
Has anyone seen this error before. Bellow is my code and a picture of the error log
Error log: http://imgur.com/II5VMzV
main code: http://imgur.com/CKZ7Dzk
open code: http://imgur.com/CKZ7Dzk
read code: http://imgur.com/UD1j4qk
wiring
Power: 3.3 on-board from the i2c port
Ground: on-board from the i2c port
SDA: on-board from the i2c port
SCL: on-board from the i2c port
Unread 09-02-2016, 11:07
Richard100 Richard100 is offline
FRC #0836 (RoboBees)
Richard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to behold
Need to see your Open code. The links for Open and Main both show main code.
Is you roboRIO I2C power jumper set to 3.3 V for the On-Board I2C interface?
Unread 09-02-2016, 13:24
Bpk9p4's Avatar
FRC #1756
sorry about that one. I will get that posted once i am home from work. Yes the I2C is set to 3.3v
I have hooked it up to 5v (from the DIO 5v pin) and i get the same results
Unread 09-02-2016, 18:46
FRC #5190
Looks like I forgot to attach the open VI.
Here it is. These 2 Vis are working via I2C on MXP.
Unread 09-02-2016, 22:31
sraque's Avatar
AKA: Steve Raque
FRC #2614 (MARS)
Hmm..not sure what it could be. I think we wired the same as you are. We wired to the main I2C port on the RIO except for power which we wired to a 5V pin on DIO. We didn't add pull-up resistors or the capacitor that is shown on Lidar-Lite Website Arduino wiring example.
I see your code has the same loop time delays as ours...try putting the I2C Enum VI in your Begin temporarily to see if you can see the Lidar at all.
Another thing I have done to convince myself that the Lidar is working is to connect it to an Arduino, if you have one, and use the software from the Lidar Lite website to see the data.
