Go to Post "Oblivious" people asking questions are what gives us an excuse to sit around on CD. - Ryan M. [more]
Unread 03-02-2016, 10:14
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
Glue shaft on back case of CIM motor
Is it legal to glue a shaft on the backend case of a CIM motor, so that we can mount an encoder or pot (like the VEX 276-2156 or 276-2216)?
The case of a CIM motor rotates when we set the angle of our wheel shooter. We need to know the shooter angle, so we planned on using an encoder or potentiometer. Space constrains makes it difficult to use a pg71 type gearmoter with encoder. We are looking at using an old worm drive, Taigene (door motor), but it has no encoder.
What other ways are there to measure our shooter angle?
Unread 03-02-2016, 10:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Glue shaft on back case of CIM motor
I don't know if you are allowed to glue something to the outside of a motor, what do the rules say? I know we are allowed to attach things using other methods, such as Zip ties or hose clamps, and I think we're allowed to attach identifying labels.
As for other suggestions of how to do it...we have no idea what your shooter thingy looks like, so it's rather difficult to make suggestions. How about some pictures?
Unread 03-02-2016, 10:51
AKA: rod nelson
I am not at shop, for a photo. The attached sketch might help.
As you can tell, my CAD skills are lacking.
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
by "set the angle", it sounds like you have something with a limited number of degrees of rotation. If this is the case, wiring a potentiometer to an analog I/O port might do the trick. Mount it to one end of the shaft and couple the shaft to the pot's stem.
Edit: picture came up during drafting the above; this looks like what you have in mind.
I can't think of any legal issues with gluing it, but I would use something removable. If you do find a legal issue with glue or just want to avoid it, you could use a rubber stopper with a small hole as a "knob" on your potentiometer and mount it so that it pushes against the mini-CIM. If it 's not glued, you may need to recalibrate from time to time.
Unread 03-02-2016, 11:00
MrForbes's Avatar
AKA: Jim
You might be able to make a simple bracket that goes across the back of the CIM, and has two or more fingers that fit under a hose clamp, around the outer housing of the motor.
My cad skilz are even worse...don't sweat it, I was able to understand what you mean from your drawing.
Unread 03-02-2016, 11:13
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
If you are looking for an encoder directly attached to the CIM motor I would recommend AndyMark CIMcoder but it is out of stock for another 2 days, I would talk to your team to see if this would work for you, it sounds more like what you should do if you want to be safe on inspection rules instead of using glue to attach an encoder which could move
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
Unread 03-02-2016, 11:20
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I don't see anything in R30 that prohibits gluing a shaft or bracket to the back of a CIM. You are not actually modifying the motor.
Unread 03-02-2016, 11:33
AKA: rod nelson
We are planning on using am-3314 for wheel speed. What we need is the angle of the CIM motor housing.
Unread 03-02-2016, 11:38
AKA: rod nelson
Someone on the team asked if we could use the single axis gyro?
My immediate response was NO.
But we can always tilt our shooter back to a home position, then use the gyro to tilt to a shoot position (to minimize drift concerns). We might try that when we have a lot of time to waste.
I love simple, and a simple bracket and a hose clamps seems better than glue. Easier to repair when it breaks.
Unread 03-02-2016, 11:50
MrForbes's Avatar
AKA: Jim
Hopefully it'll work!
If you think that is simple, wait till you see our robot...I only hope it works...
Unread 03-02-2016, 12:01
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
We are using a string pot to keep track of the angle of the shooter. We should be able to know the angle of the shooter that way.
Gluing onto the motor just doesn't feel like a good idea overall. It will work, but during competition it might come loose on a violent fall from a tower for instance.
Unread 03-02-2016, 12:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Keep in mind, that part of the motor gets extremely hot.
Unread 03-02-2016, 14:50
MrForbes's Avatar
AKA: Jim
On a drive motor, yeah, it'll get hot. On a shooter motor that has very little load, it should not get hot.
Unread 03-02-2016, 16:23
Am I missing something? The back of the CIM motor does not have a shaft so to attach an encoder you would have to modify the case. R30 is very specific about what allowed mods can be made to motors and drilling into the case is not allowed.
Unread 03-02-2016, 16:30
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
They are not trying to determine the rotation of the shaft, but of the enclosure/housing.
