Go to Post How about instead of using the flag we just all wrap out robots in color saran wrap. there! problem sovled! - John Gutmann [more]
Unread 02-02-2016, 14:53
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Re: Chain Tension-er?
We found that flexible sprocket device too and I was wondering if something like that could be 3D printed out of some material that would give a similar effect. Anyone have thoughts about this?
Also from my reading it seems like tensioning addresses at least two separate factors. The first is making the chain the correct length for the application. This can also be solved with careful design and manufacturing. The second is compensating for chain stretch. Which of these sounds like the bigger factor for an application like a drive train?
Alan Gilgenbach
C.O.R.E 2062
Unread 02-02-2016, 18:57
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
I suspect if you could get it to print right with the proper spacing, ABS would have enough flex without being too squishy or too rigid. The trick is getting it right.
As far as spacing, the only actual problem is length, which chain stretch contributes to. The three options are 1. ignore it, 2. tension it, 3. have some way to move a sprocket around so you can move it back when chain stretch.
Unread 02-02-2016, 19:41
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I would laser cut this thing before I tried to 3D print them. But even that seems a bit sketchy to me. As I recall (I have only held one in my hand once and it was years ago), the reason the device is a hoop and not a disk is that the hoop structure allows it to become an ellipse and thereby add some springiness to the system. As slack becomes available the ellipse gets more round and takes up that slack.
Bottom line, this thing flexes. I think a 3D printed version is doomed to destroy itself over time.
Dr. Joe J.
Team #88, TJ2
Unread 02-02-2016, 19:59
elil elil is offline
Lead Engineer
AKA: Eli
FRC #1719 (The Umberella Corporation)
elil is an unknown quantity at this point
I highly recommend an idler pulley. My team has used a bolt with a piece of pvc around it. To attach the bolt, we tighten it with a lock nut through a slot on a piece of sheet metal. The one thing about this is that the nut has to be really tightened down. Otherwise it's about as light and simple as you can get.
We've also used spring loaded tensioners. These had their advantages and disadvantages. The big advantage was never needing to worry that the chain was tensioned after the tensioner was attached. The disadvantages are of course cost, but also weight. Additionally, support like a wood block must be added to the bolts used to attach the spring tensioners if they cannot be mounted directly onto a frame element.
We have also used 3d printed pieces on a belt drive. They are a half moon shape sized to tension the belt without needing to be adjusted.
Unread 03-02-2016, 11:58
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
We've used this product from McMaster every year.
Expensive, but totally worth it.
http://www.mcmaster.com/#chain-tensioners/=10yrv27
Lead Mentor - Team 6367 - The Brooke High ElectroLights
Former Mentor - Team 5969 - The English Skunkworks
Former Mentor - Team 1754 - The Excel Nitro Knights
Unread 03-02-2016, 12:04
AKA: Dr. Joe
FRC #0088 (TJ2)
Counter point.
Build your own. It's not that hard and it is totally worth it. ;-)
Dr. Joe J.
P.S. Serious. Designing chain tensioning into your robot is just a skill that FIRST teams should acquire and then nurture and grow. It is a core skill that makes your robot SO MUCH more reliable if you do it right. Learn it. Love it. Pass it on before you graduate. JJ
Team #88, TJ2
Unread 03-02-2016, 13:31
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by Massako View Post
lol thanks. i dont know how well this would work on a drive train but we can defiantly try it.
When I was on 228 in 2011, we used CNC milled polycarbonate floating idlers to tension the 25-pitch roller chain in the drive train. They never fell out, but had to be adjusted a few times early on as the chain 'stretched'.
I don't have any photos of the 2011 drive train usage, but I do have one available from when I first used them in 2009. We used the same style polycarbonate floating idlers in 2011.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-02-2016, 13:51
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
For a nice history lesson, research how WCP got its start. linky
Hi!
