Go to Post If it were not about winning, it would not be called a competition - but FRC is much more than winning a competition. - JaneYoung [more]
Unread 03-02-2016, 15:40
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Toggling Between Two buttons
if button.pressed():
    if !buttonWasPressed:
         buttonWasPressed = True
         motorSet = 1 - motorSet
else:
         buttonWasPressed = False
motor.set(motorSet)
python pseudocode
Unread 03-02-2016, 15:58
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Originally Posted by Arhowk View Post
else:
motor.set(motorSet)
python pseudocode
That doesn't seem like what he is asking for.
I'm not a programmer at all but I think a variable is the correct way to deal with your request.
if Button A is pressed then set variable "X" to 1.
if Button B is pressed then set variable "X" to 2.
if "X" = 1 then Motor runs one way
if "X" = 2 then motor runs the other way
Again. Not a programmer. Just how your request sounds in my head.
Unread 03-02-2016, 16:11
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
This is correct.
Note that as it stands once one of these two buttons is pressed and the motor turns on, there is no way to turn it off again.
