Go to Post Okay, who's willing to admit they treat their robot as a pet? - Bill Moore [more]
Unread 03-02-2016, 17:55
Lesafian Lesafian is offline
AKA: Jeremy Styma
FRC #6077 (Wiking Kujon)
Rookie Year: 2016
Lesafian is an unknown quantity at this point
Angry Code does not work, and there seems to be 0 issues.
I've written code for our robot, but it is not working. There are 0 errors in Eclipse, and 0 errors in the driver station. I'm not sure if it's an issue with the code or with our electric wiring. Here is the code, please let me know if there's anything wrong.
package org.usfirst.frc.team6077.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.TalonSRX;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends SampleRobot {
        // RobotDrive Declaration
	RobotDrive drive;
	// Compressor Declaration
	Compressor compressor;
	// Solenoid Declaration
	DoubleSolenoid doublesolenoid;
	Solenoid solenoid;
	// Joystick Declaration
	Joystick xboxController;
	// Motor Controller Declaration
	TalonSRX armMotor;
	TalonSRX slideMotor;
	Victor drivemotor1;
	Victor drivemotor2;
	// Autonomous Names
	final String defaultAuto = "Default";
	final String customAuto = "Autonomous Choice 1";
	final String customAuto2 = "Autonomous Choice 2";
	final String customAuto3 = "Autonomous Choice 3";
	final String customAuto4 = "Autonomous Choice 4";
	final String customAuto5 = "Autonomous Choice 5";
	// Chooser
	SendableChooser chooser;
	public Robot() {
		//Change values later
		drivemotor1 = new Victor(0);
		drivemotor2 = new Victor(2);
		compressor = new Compressor(0);
		drive = new RobotDrive(drivemotor1, drivemotor2);
		drive.setExpiration(0.1);
		xboxController = new Joystick(0);
		armMotor = new TalonSRX(5);
		slideMotor = new TalonSRX(4);
		doublesolenoid = new DoubleSolenoid(0, 1);
		solenoid = new Solenoid(2);
		chooser = new SendableChooser();
	public void robotInit() {
		compressor.setClosedLoopControl(true);
		chooser.addDefault("Default Auto", defaultAuto);
		chooser.addObject("Autonomous Choice 1", customAuto);
		chooser.addObject("Autonomous Choice 2", customAuto2);
		chooser.addObject("Autonomous Choice 3", customAuto3);
		chooser.addObject("Autonomous Choice 4", customAuto4);
		chooser.addObject("Autonomous Choice 5", customAuto5);
		SmartDashboard.putData("Autonomous Chooser", chooser);
	public void autonomous() {
		compressor.getPressureSwitchValue();
		drive.setSafetyEnabled(false);
		String autoSelected = (String) chooser.getSelected();
		System.out.println("Autonomous Mode selected: " + autoSelected);
		switch (autoSelected) {
		case customAuto5:
			break;
		case customAuto4:
			break;
		case customAuto3:
			break;
		case customAuto2:
			break;
		case customAuto:
			break;
		case defaultAuto:
		default:
			break;
		Scheduler.getInstance().run();
	public void operatorControl() {
		drive.setSafetyEnabled(true);
		while (isOperatorControl() && isEnabled()) {
			// Move robot using left and right joystick
			drive.tankDrive(xboxController.getRawAxis(2), xboxController.getRawAxis(5));
			// Lift and lower the arms using the right and left bumper.
			if (xboxController.getRawButton(5)) {
				armMotor.set(1);
			} else if (xboxController.getRawButton(4)) {
				armMotor.set(-1);
			else {
				armMotor.set(0);
			// Move sliding mechanism forwards and backwardss
			if (Math.abs(xboxController.getRawAxis(5)) > .1) {
				slideMotor.set(xboxController.getRawAxis(5));
			else {
				slideMotor.set(0);
			// Open and close the claw
			if (xboxController.getRawButton(2)) {
				doublesolenoid.set(DoubleSolenoid.Value.kForward);
			else if (xboxController.getRawButton(1)) {
				doublesolenoid.set(DoubleSolenoid.Value.kReverse);
	public void test() {
Unread 03-02-2016, 18:11
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Code does not work, and there seems to be 0 issues.
Which part? Also, why do you have a Robot constructor? You don't need that
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 03-02-2016, 18:18
AKA: Jeremy Styma
Rookie Year: 2016
Nothing works, and what do you mean?
Unread 03-02-2016, 18:36
ArchdukeTim
So you have public Robot(). You don't need this method. Just put it all in robotInit
Unread 03-02-2016, 20:14
c0d3rman's Avatar
c0d3rman c0d3rman is offline
Programming Captain
AKA: Yoni Lerner
FRC #4904 (Bot Provoking)
c0d3rman is an unknown quantity at this point
When you say "nothing works", what exactly do you mean? What is happening when you enable?
Unread 03-02-2016, 20:45
AKA: Jeremy Styma
Rookie Year: 2016
The drive motors do not turn, the arm motor does not turn, the slide motor does not turn. The compressor works though.
Unread 03-02-2016, 20:52
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
Maybe your joystick isn't working?
Have you had the code working before? If so, what changes have been made?
Unread 03-02-2016, 21:04
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
If there are 0 errors, be sure that you have the rioLog open in eclipse (open from the view menu). Also, assuming that you do not have any errors, have you used this roboRio successfully before now? Have you performed any recent updates? Have you installed Java on the rio?
2013-2014: Electrical, Mechanical
2014-2017: Team Captain
Unread 03-02-2016, 22:57
AKA: Jeremy Styma
Rookie Year: 2016
Yes, it has worked successfully. No I have not updated anything. No, there are 0 Rio log errors. Yes Ive installed java on it.
Unread 04-02-2016, 08:25
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Try adding some diagnostic tools to your code.
For example at the end of your constructor, try adding the following two lines:
LiveWindow.addActuator("Drive", "Left Motor", drivemotor1);
LiveWindow.addActuator("Drive", "Right Motor", drivemotor2);
If you deploy the code and put your Driver Station in "Test" mode, you should see two sliders appear on your SmartDashboard related to your drive motors. You should be able to adjust the sliders and see the motors turn.
You can also add "debug output" that appears during normal operation. Try adding the following field (lastDashboardUpdate) and method to your Robot class:
        // time stamp of last time we sent values to dash board
	private double lastDashboardUpdate = 0;
	private void updateDashboard() {
		double now = Timer.getFPGATimestamp();
		// Diagnostic updates about 10 times a second
		if ((now - lastDashboardUpdate) > 0.1) {
			lastDashboardUpdate = now;
                        // Diagnostic information about the state of the robot
			SmartDashboard.putNumber("Left Stick", xboxController.getRawAxis(2));
			SmartDashboard.putNumber("Right Stick", xboxController.getRawAxis(5));
			SmartDashboard.putNumber("Left Drive Power", drivemotor1.get());
			SmartDashboard.putNumber("Right Drive Power", drivemotor2.get());
Then, inside the while() loop in your operatorControl() method, call the new updateDashboard() method.
Deploy the code and start the driver station in Teleop mode. You should see values update on your smart dashboard corresponding to the inputs on your game pad and the output power of your drive motors. If you see zero values on your joysticks even when you are moving them, check the driver station console and make certain that your gamepad has not been re-mapped to a different port.
After you get things working on the drive, you can comment out the debug output in the updateDashboard() method and use this approach to troubleshoot the rest of your components.
Unread 04-02-2016, 08:52
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
First, as someone who does software for a living, I would be an extremely rich person if I had $0.05 for every time I've heard (or said) those words.
Second, your location says Posen. Is that as in Posen, MI? That would be pretty cool because I'm from that general area.
Anyway, sorry to sidetrack the coversation.
Unread 04-02-2016, 18:13
AKA: Jeremy Styma
Rookie Year: 2016
Posen, MI.
