Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
Unread 03-02-2016, 12:51
Lesafian Lesafian is offline
AKA: Jeremy Styma
FRC #6077 (Wiking Kujon)
Rookie Year: 2016
Lesafian is an unknown quantity at this point
Is my Java code ok?
Hi, I'm head programmer of Team 6077 (rookie team). I was wondering if one of you could be kind enough to look through my code (Java) to make sure it follows the rules, and theoretically works.
package org.usfirst.frc.team6077.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.TalonSRX;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends SampleRobot {
        // RobotDrive Declaration
	RobotDrive drive;
	// Compressor Declaration
	Compressor compressor;
	// Solenoid Declaration
	DoubleSolenoid doublesolenoid;
	Solenoid solenoid;
	// Joystick Declaration
	Joystick xboxController;
	// Motor Controller Declaration
	TalonSRX armMotor;
	TalonSRX slideMotor;
	Victor drivemotor1;
	Victor drivemotor2;
	// Autonomous Choices
	final String defaultAuto = "Default";
	final String customAuto = "Autonomous Choice 1";
	final String customAuto2 = "Autonomous Choice 2";
	final String customAuto3 = "Autonomous Choice 3";
	final String customAuto4 = "Autonomous Choice 4";
	final String customAuto5 = "Autonomous Choice 5";
	// Chooser
	SendableChooser chooser;
	public Robot() {
		drivemotor1 = new Victor(0);
		drivemotor2 = new Victor(2);
		compressor = new Compressor(0);
		drive = new RobotDrive(0, 2);
		drive.setExpiration(0.1);
		xboxController = new Joystick(0);
		armMotor = new TalonSRX(5);
		slideMotor = new TalonSRX(6);
		doublesolenoid = new DoubleSolenoid(0, 1);
		solenoid = new Solenoid(2);
		chooser = new SendableChooser();
	public void robotInit() {
		compressor.setClosedLoopControl(true);
		chooser.addDefault("Default Auto", defaultAuto);
		chooser.addObject("Autonomous Choice 1", customAuto);
		chooser.addObject("Autonomous Choice 2", customAuto2);
		chooser.addObject("Autonomous Choice 3", customAuto3);
		chooser.addObject("Autonomous Choice 4", customAuto4);
		chooser.addObject("Autonomous Choice 5", customAuto5);
		SmartDashboard.putData("Autonomous Chooser", chooser);
	public void autonomous() {
		drive.setSafetyEnabled(false);
		String autoSelected = (String) chooser.getSelected();
		System.out.println("Autonomous Mode selected: " + autoSelected);
		switch (autoSelected) {
		case customAuto5:
			break;
		case customAuto4:
			break;
		case customAuto3:
			break;
		case customAuto2:
			break;
		case customAuto:
			break;
		case defaultAuto:
		default:
			break;
		Scheduler.getInstance().run();
	public void operatorControl() {
		drive.setSafetyEnabled(true);
		while (isOperatorControl() && isEnabled()) {
			// Move robot using left and right joystick
			drive.tankDrive(xboxController.getRawAxis(1), xboxController.getRawAxis(5));
			// Lift and lower the arms using the right and left bumper.
			if (xboxController.getRawButton(5)) {
				armMotor.set(1);
			} else if (xboxController.getRawButton(4)) {
				armMotor.set(-1);
			else {
				armMotor.set(0);
			// Move sliding mechanism forwards and backwards
			if (Math.abs(xboxController.getRawAxis(5)) > .1) {
				slideMotor.set(1);
			} else if (Math.abs(xboxController.getRawAxis(5)) < -.1) {
				slideMotor.set(-1);
			else {
				slideMotor.set(0);
			// Open and close the claw
			if (xboxController.getRawButton(2)) {
				doublesolenoid.set(DoubleSolenoid.Value.kForward);
			else if (xboxController.getRawButton(1)) {
				doublesolenoid.set(DoubleSolenoid.Value.kReverse);
			else {
				doublesolenoid.set(DoubleSolenoid.Value.kOff);
	public void test() {
Thanks in advance!
Unread 03-02-2016, 12:59
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Is my Java code ok?
the last line where you set your solenoid to kOff: it will cut the input pressure to your mechanism, meaning it will not hold the last position. you likely don't want this line
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 03-02-2016, 13:05
AKA: Jeremy Styma
Rookie Year: 2016
Thank you, I'll fix that! As far as everything else does it look ok?
Unread 03-02-2016, 13:13
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I see that you initialized the RobotDrive with the port numbers of your speed controllers. I believe that this will work correctly because you are using victors, but it would be better practice to initialize it with the two speed controllers you already initialized.
drive = new RobotDrive(drivermotor1, drivemotor2);
Unread 03-02-2016, 13:29
RayG RayG is offline
FRC #1796 (RoboTigers)
RayG is an unknown quantity at this point
On the tank drive line, you want to be using axis 2 and 5 for left and right Y axis'.
Unread 03-02-2016, 14:00
Drive Coach
AKA: Antoine L.
i guess the goal with using an axis for your sliding mechanism was to control the speed? Then you should use your joystick axis value instead of 1 and -1 (full speed)
also, your condition testing with Math.abs removes the negative sign, so your second if test will never work
This is how it could be made
                        //if your axis is not between -0.1 and 0.1
                                //set your motor output to the axis value
				slideMotor.set(xboxController.getRawAxis(5));
			}else {
				slideMotor.set(0);
Unread 03-02-2016, 14:54
AKA: Jeremy Styma
Rookie Year: 2016
Won't this only work if I move the stick up? Shouldn't I need both > and < .1 if I'd like to both increase and decrease
Example of what I mean:
			}else if (Math.abs(xboxController.getRawAxis(5)) < .1 {
Unread 03-02-2016, 15:20
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
soundfx is an unknown quantity at this point
MaGiC_PiKaChU is correct. His code will test the absolute value for the threshold, then set the motor power to the joystick. Yours would probably work just as well, but the else if is redundant since it will never evaluate to true.
Unread 03-02-2016, 15:51
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
For us, although the code said "build successful" for code similar as shown below, it will throw an error (on the robot) and the driver station noted no code on the robot.
So use the correction shared by Joey:
Originally Posted by Joey1939 View Post
Once we did this change, everything worked fine.
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
Unread 03-02-2016, 18:05
Drive Coach
AKA: Antoine L.
No. The math.abs function transforms your value to positive.
if (Math.abs(xboxController.getRawAxis(5) < .1) is equivalent to if(xboxController.getRawAxis(5) < .1 && xboxController.getRawAxis(5) > -.1)
Let's say you put Math.abs(-0.05). that will output 0.05. I recommend you try it out and print in the Riolog. That saves you a few lines in your code, instead of testing for both positive and negative values.
Unread 03-02-2016, 19:33
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
if (Math.abs(xboxController.getRawAxis(5) < .1) is equivalent to if(xboxController.getRawAxis(5) < .1 || xboxController.getRawAxis(5) > -.1)
That should be an && (and) in your compound statement instead of an or.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 03-02-2016, 19:42
Drive Coach
AKA: Antoine L.
you're right. Fixed it
