Go to Post Look for metal shavings in a pwm port; that's caused us to crash plenty of times. - Gary Dillard [more]
Unread 03-02-2016, 20:18
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
Robot Turns Off During Teleop
All the sudden, it seems that we are having an issue where our Robot turns off after about a minute into running in TeleOP mode. Anyone have any solutions?
Unread 03-02-2016, 20:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Robot Turns Off During Teleop
Can you post a log file of this happening?
Unread 03-02-2016, 20:27
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
When you say it "turns off", do you mean that all the lights on the roborio are off and stay off? Or that it seems to reboot?
If the roborio lights are off, does the PDP have lights on?
If not, is the main breaker tripping?
Unread 03-02-2016, 21:18
DonRotolo's Avatar
Back to humble
FRC #0832
I theorize that one of your #6 wire connections is loose.
Unread 05-02-2016, 07:51
I would start at the battery and inspect each connection from there to the PDP. The battery cables should be snug and not wobble. The connections at the breaker, ditto. The connections at the PDP, ditto. Also check that the fuses at are firmly pressed into the PDP. Firm means that if you grab with your fingers you cannot pull them out. When you press them in, it will bruise your thumb a little.
These are very important connections, as you can see, so check them periodically. This will be a rough game, and things will work loose.
Greg McKaskle
