Go to Post IF WildstangIsAwesome = True and SkaIsAwesome THEN Act = AWESOME End IF - Rohith Surampudi [more]
Unread 03-02-2016, 23:52
Re: RoboRio Communication Issues
From the statuses you've described it sounds like your PC communicates just fine with the roboRIO.
Is it just a problem with LabVIEW that you are describing?
Are you attempting to Run from Robot Main?
Are you able to use Build Specifications to Build and Run as startup?
Is there something else important that I didn't catch from your descriptions?
