Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 03-02-2016, 20:01
ktrod ktrod is offline
FRC #1073
ktrod is an unknown quantity at this point
GRIP Issues with RPi2
Following this tutorial for setting up GRIP on a Raspberry Pi 2, I was able to successfully deploy the required libraries and the grip.jar and project.grip into my RPi2 running Ubuntu Mate 15.10.1. However, when attempting to run GRIP with the provided command for running GRIP,
env LD_LIBRARY_PATH=/home/team1073/vision/grip:LD_LIBRARY_PATH java -jar /home/team1073/vision/grip/grip.jar /home/team1073/vision/grip/project.grip
, I receive the following uncaught exception
Loading Dependency Injection Framework
Jan 30, 2016 11:46:08 PM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
Jan 30, 2016 11:46:09 PM java.util.logging.LogManager$RootLogger log
CONFIG: GRIP Version: 1.1.1
platform: /Linux/arm/
Jan 30, 2016 11:46:28 PM edu.wpi.grip.core.GRIPCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[main,5,main]
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.UnsatisfiedLinkError: /tmp/libNetworkTablesJNI3879377472892182855.so: /tmp/libNetworkTablesJNI3879377472892182855.so: cannot open shared object file: No such file or directory
  at edu.wpi.grip.core.operations.networktables.NTManager.<init>(Unknown Source)
  at edu.wpi.grip.core.operations.networktables.NTManager.class(Unknown Source)
  while locating edu.wpi.grip.core.operations.networktables.NTManager
    for field at edu.wpi.grip.core.Pipeline.ntManager(Unknown Source)
  at edu.wpi.grip.core.Pipeline.class(Unknown Source)
  while locating edu.wpi.grip.core.Pipeline
    for field at edu.wpi.grip.core.serialization.Project.pipeline(Unknown Source)
  at edu.wpi.grip.core.serialization.Project.class(Unknown Source)
  while locating edu.wpi.grip.core.serialization.Project
    for field at edu.wpi.grip.core.Main.project(Unknown Source)
  while locating edu.wpi.grip.core.Main
Caused by: java.lang.UnsatisfiedLinkError: /tmp/libNetworkTablesJNI3879377472892182855.so: /tmp/libNetworkTablesJNI3879377472892182855.so: cannot open shared object file: No such file or directory
	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
	at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938)
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1821)
	at java.lang.Runtime.load0(Runtime.java:809)
	at java.lang.System.load(System.java:1086)
	at edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:55)
	at edu.wpi.grip.core.operations.networktables.NTManager.<init>(NTManager.java:50)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
	at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:86)
	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:105)
	at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
	at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:267)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1103)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
	at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:145)
	at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41)
	at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:54)
	at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:132)
	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
	at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1016)
	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1012)
	at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1051)
	at edu.wpi.grip.core.Main.main(Main.java:41)
2) Error injecting constructor, java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
    for field at edu.wpi.grip.core.serialization.StepConverter.pipeline(Unknown Source)
  while locating edu.wpi.grip.core.serialization.StepConverter
    for parameter 0 at edu.wpi.grip.core.serialization.Project.initialize(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
	at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
	at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
	at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:84)
3) Error injecting constructor, java.lang.NoClassDefFoundError: Could not initialize class edu.wpi.first.wpilibj.networktables.NetworkTablesJNI
    for field at edu.wpi.grip.core.serialization.SocketConverter.pipeline(Unknown Source)
  while locating edu.wpi.grip.core.serialization.SocketConverter
    for parameter 2 at edu.wpi.grip.core.serialization.Project.initialize(Unknown Source)
3 errors
	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1025)
From looking at it, it appears as though GRIP is looking for libraries that aren't there. If someone could provide insight as how to fix this, it would be greatly appreciated.
Unread 04-02-2016, 09:15
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
Re: GRIP Issues with RPi2
I can't help you with the GRIP problems on the Pi2. Since they were still working on getting it running on the Pi2 when got our Pi, we decided to install OpenCV, with a python server talking pyNetworkTables. If you decide to go that route, let me know and I'll point to some instructions that worked for me. Heads up, the openCV install takes 4-5 hours.
In parallel, we developed GRIP on DS. Since both options use NetworkTables, the code doesn't care where the vision processing is done. So we'll test both and choose.
Brian
Unread 04-02-2016, 11:33
xjschwen xjschwen is offline
FRC #3668
xjschwen is an unknown quantity at this point
Great open CV on RP2
http://www.pyimagesearch.com/2015/02...ry-pi-2-and-b/
Unread 04-02-2016, 12:43
Ubiquity Ubiquity is offline
FRC #5027
Ubiquity is an unknown quantity at this point
I am not sure how well straight OpenCV works on the RPi2 with the RPi2 camera, But ROS Indigo + Ubuntu 14.04 (Robot Operating System, which has OpenCV included) works well on the Pi. In addition I heard there is a Library for MyRio (Labview) That integrates ROS and Labview. Not sure if that will help you in the next three weeks. This is a mountainous learning curve.
Former mentor: 255(4y), 254(2y), 668(1y), 751(1y),5027
Current mentor 2854, 5905
Volunteer, Ref, Inspector, Judge, FTA
Nat. Champion 2000(255), Nat. Chairman's 2004(254), SVR Champion 2015(5027)
(Botball N. Champ 2001)
Unread 04-02-2016, 13:53
FRC #1261
Originally Posted by xjschwen View Post
This is the generic link I found, and lead to the one that we used. I didn't use this link due to the distribution we had. If you see the update just before Step 0, we used the Raspian Jessie instructions since that's the distro we had.
Important: some of the steps have a paragraph following the command. Sometimes the extra paragraph might make you skip or change a command. So make sure to read everything first and THEN do the install.
Brian
