Go to Post 20,000 students 900 teams robots Gracious professionalism = FIRST - Bcahn836 [more]
Unread 04-02-2016, 09:16
csilent csilent is offline
FRC #1896
csilent is an unknown quantity at this point
Microsoft USB Camera Error
We are trying to use a Microsoft Lifecam HD-3000 as a usb camera through the roborio. We have been using the code from the simple vision example:
CameraServer::GetInstance()->SetQuality(50);
CameraServer::GetInstance()->StartAutomaticCapture("cam0");
However, once we start the driver station we get this error:
at /opt/GenICam_v2_3/bin/Linux_armv7-a/libstdc++.so.6(+0xa2cb0) [0xb5e77cb0]Error on line 207 Incompatible State: The operation cannot be completed: Choose "USB Camera HW" on the dashboard
at CameraServer::Serve()
We have eventually gotten the camera feed to show up in java dashboard, but only after creating a couple of different camera objects and then restarting the dashboard. Otherwise it just comes up as connection reset or robot has stopped returning images. Any advice?
Unread 04-02-2016, 11:05
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Microsoft USB Camera Error
We debugged this problem (we had it too) and discovered that it's because CameraServer expects all client information to arrive in one packet. The dashboard sends it in 2 packets, so CameraServer thinks part of the information is missing. You can find our fix for this here.
Unread 04-02-2016, 11:40
FRC #1896
Thanks, a little bit confused on where to put the code though. Does it go inside of a header file?
Unread 07-02-2016, 17:57
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Hey, same problem, appreciate the solution. Where is this file to fix it?
Unread 08-02-2016, 18:41
kmckay's Avatar
Rookie Year: 2015
FYI, this seems to be a known error:
https://usfirst.collab.net/sf/go/art...4549746553 31
Unread 08-02-2016, 19:14
MaikeruKonare's Avatar
MaikeruKonare MaikeruKonare is offline
Programming Division Captain
AKA: Michael Conard
FRC #4237 (Team Lance-a-Bot)
MaikeruKonare is an unknown quantity at this point
When using the USB Cameras I would suggest not doing automatic capture. The following is something I made that works. This code is for toggling between two USB cameras, because we have a front and back cam.
CPP File:
 * LHSVision.cpp
 *  Created on: Jan 26, 2016
 *      Author: Michael Conard
 *  THING TO CHECK:
 *  	-In Internet Explorer, roborio-4237-frc.local,
 *  	 confirm the camera names in Silverlight. These
 *  	 should be "cam0", "cam1", or "cam2".
 *  	-These names can be adjusted in the CAMERA
 *  	 namespace.
#include "WPILib.h"
#include "LHSVision.h"
namespace XBOX		//Joystick Constants
	const int NODE_ID = 1;
	const int XBOX_A_BUTTON  = 1;
	const int XBOX_X_BUTTON = 3;
	const int XBOX_LEFT_X = 0;
	const int XBOX_LEFT_Y = 1;
namespace CAMERA	//Camera Names
	const char* CAM_ONE = "cam1";
	const char* CAM_TWO = "cam2";
//NOTE: Camera 1 is the default camera. Can toggle to 2 later.
LHSVision::LHSVision(RobotDrive* pRobot, Joystick* pXbox) //Constructor
	printf("File %18s Date %s Time %s Object %p\n",__FILE__,__DATE__, __TIME__, this);
	frame = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
	IMAQdxOpenCamera(CAMERA::CAM_ONE, IMAQdxCameraControlModeController, &session);
	Wait(.5);
	IMAQdxConfigureGrab(session);
	Wait(.5);
	IMAQdxStartAcquisition(session);
	Wait(.5);
	frame2 = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
	mRobot = pRobot;
	mXbox = pXbox;
LHSVision::~LHSVision() //Destructor
	delete mXbox;
	delete mRobot;
//Used for closing and stopping acquisition of a camera
void LHSVision::StopCamera(int camNum)
	if(camNum == 1)	//Camera 1 Shutdown
		IMAQdxStopAcquisition(session);
		Wait(.01);
		IMAQdxCloseCamera(session);
	else			//Camera 2 Shutdown
		IMAQdxStopAcquisition(session2);
		Wait(.01);
		IMAQdxCloseCamera(session2);
//Used for opening, configuring, and starting acquisition of a camera
void LHSVision::StartCamera(int camNum)
	if(camNum == 1) //Camera 1 Startup
		Wait(.01);
		Wait(.01);
		Wait(.01);
	else			//Camera 2 Startup
		IMAQdxOpenCamera(CAMERA::CAM_TWO, IMAQdxCameraControlModeController, &session2);
		Wait(.01);
		IMAQdxConfigureGrab(session2);
		Wait(.01);
		IMAQdxStartAcquisition(session2);
		Wait(.01);
//Send image to FRC PC Dashboard
void LHSVision::SendToDashboard(Image *image)
	CameraServer::GetInstance()->SetImage(image);
void LHSVision::UpdateVision() //by Michael
	if(mXbox->GetRawButton(XBOX::XBOX_A_BUTTON) == true)	//Toggle on A button press
		while(mXbox->GetRawButton(XBOX::XBOX_A_BUTTON) == true)	//Prevents multi-press
		if(send == 1)
			StopCamera(1);	//Stop Cam 1
			StartCamera(2);	//Start Cam 2
			printf("\nActivating Camera 2 - Raw Image Display\n\n");
			send = 2;
		else
			StopCamera(2);	//Stop Cam 2
			StartCamera(1);	//Start Cam 1
			printf("\nActivating Camera 1 - Raw Image Display\n\n");
			send = 1;
	if(send == 1)
		IMAQdxGrab(session, frame, true, NULL);
		SendToDashboard(frame);		//Send Cam 1
		Wait(.1);
	else
		IMAQdxGrab(session2, frame2, true, NULL);
		SendToDashboard(frame2);	//Send Cam 2
		Wait(.1);
Header File:
 * LHSVision.h
 *  Created on: Jan 25, 2016
#ifndef LHS_VISION_H
#define LHS_VISION_H
class RobotDrive;
class Joystick;
class LHSVision
public:
	LHSVision(RobotDrive*, Joystick*); //Constructor
	~LHSVision();	//Destructor
	void SendToDashboard(Image*); //Send Image to Dashboard
	void UpdateVision();	//Toggle and Display Camera
	void StopCamera(int);	//Close Specified Camera
	void StartCamera(int);	//Start Specified Camera
private:
	IMAQdxSession session;
	Image* frame;
	IMAQdxSession session2;
	Image* frame2;
	RobotDrive* mRobot;
	Joystick* mXbox;
	int send = 1;
#endif
My Main File:
 * Robot.cpp
 *  This program requires:
 *  		-XBox Joystick
 *  		-Left Drive Talon
 *  		-Right Drive Talon
 *  		-Two USB Cameras on Roborio
 *  Ports can be adjusted below in PORTS namespace.
 *  Controls:
 *  	-Forward/Reverse, Left Y Axis
 *  	-Rotating/Spinning, Left X Axis
 *  	-Toggling Front/Back Camera, A Button
 *  Info: The cameras display to the FRC PC Dashboard.
 * 		  To open this: FRC Driver Station -> Third
 * 		  Tab (Setup) -> Set "Dashboard Type" to "Default"
 * 		  In the FRC PC Dashboard near the bottom-middle,
 * 		  change "Camera Off" to "USB Camera HW".
#include "WPILib.h"
namespace PORTS	//Motor Constants
	const int LEFT_MOTOR = 0;
	const int RIGHT_MOTOR = 1;
class Robot: public SampleRobot
private:
	RobotDrive* mRobot;		//RobotDrive with two Talons
	Joystick* mStick;		//Joystick
	LHSVision* mLHSVision;	//Raw Image Display
public:
	Robot();				//Constructor
	~Robot();				//Destructor
	void OperatorControl();	//Can Drive and Toggle Cameras
	void Autonomous();		//No Content
Robot::Robot()	//Constructor
	mRobot = new RobotDrive(PORTS::LEFT_MOTOR, PORTS::RIGHT_MOTOR);
	mStick = new Joystick(XBOX::NODE_ID);
	mLHSVision = new LHSVision(mRobot, mStick);	//LHSVision requires a RobotDrive and Joystick
Robot::~Robot()	//Destructor
	delete mRobot;
	delete mStick;
void Robot::OperatorControl()	//Driving and Camera Toggling
	while(IsOperatorControl() && IsEnabled())
		mRobot->ArcadeDrive(mStick->GetRawAxis(XBOX::XBOX_LEFT_Y), mStick->GetRawAxis(XBOX::XBOX_LEFT_X));
		mLHSVision->UpdateVision();
		Wait(0.02);
void Robot::Autonomous()	//No Content
	while(IsAutonomous() && IsEnabled())
		printf("Autonomous!\n");
START_ROBOT_CLASS(Robot)
I hope this helps. If you need me to simplify my code structure to do only one USB camera let me know.
Unread 09-02-2016, 09:58
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Put LCameraServer.cpp and LCameraServer.h in your project, and then use the LCameraServer class as you would CameraServer. Don't use both at the same time (of course).
I would also recommend not using automatic capture. Grab your images using IMAQdx and call SetImage directly.
