Go to Post I'm throwing the Unnecessary Sarcasm Flag here. - Joe Johnson [more]
Unread 02-04-2016, 11:40 AM
csilent csilent is offline
FRC #1896
csilent is an unknown quantity at this point
Re: Microsoft USB Camera Error
Thanks, a little bit confused on where to put the code though. Does it go inside of a header file?
Unread 02-07-2016, 05:57 PM
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Hey, same problem, appreciate the solution. Where is this file to fix it?
Unread 02-08-2016, 06:41 PM
kmckay's Avatar
Rookie Year: 2015
FYI, this seems to be a known error:
https://usfirst.collab.net/sf/go/art...4549746553 31
Unread 02-09-2016, 09:58 AM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Put LCameraServer.cpp and LCameraServer.h in your project, and then use the LCameraServer class as you would CameraServer. Don't use both at the same time (of course).
I would also recommend not using automatic capture. Grab your images using IMAQdx and call SetImage directly.
