Go to Post We want you here, and we want you back. Welcome. - Gary Dillard [more]
Unread 27-01-2016, 22:36
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
getting output from opencv onto smartdashboard
Hello. We are testing some vision code we wrote on the roboRIO and are using opencv on the RIO. I would like to be able to get the output steam of jpegs from opencv to the c++ smartdashboard.
I have seen you can use CameraServer's setImage, but how does that work in correlation with the smartdashboard?
Thanks,
Drew
Unread 04-02-2016, 11:54
mikhail's Avatar
mikhail mikhail is offline
AKA: Mentor of The Software ERRORs
FRC #3130 (ERRORS)
mikhail is an unknown quantity at this point
Re: getting output from opencv onto smartdashboard
SmartDashboard's and OpenCV's formats are not compatible with each others but there is a trick. There could be better methods but here's what worked for me, at least for debugging purposes. Save your cv::Mat, the one you want to see, probably after all the OpenCV processing with marks and numbers on it, using imwrite() somewhere in RoboRIO's filesystem. I used /var/volatile/tmp/ directory as I guess it's some kind of a RAM-disk on RoboRIO, so all the IO should happen in-memory. Then create an IMAQ image object, something like "Image image = frcCreateImage(IMAQ_IMAGE_RGB);", and read your file into it and set it as the current frame with the CameraServer:
void CameraFeedCommand::CameraFeedCommand()
void CameraFeedCommand::Execute()
    frcReadImage(image,"/var/volatile/tmp/opencv-frame.png");
    CameraServer::GetInstance()->SetImage(image);
PS: Do not run the automatic capture with the CameraServer, feed it the images yourself repeatedly.
PPS: Set the camera mode on the Dashboard to "USB camera HW"
Unread 04-02-2016, 12:41
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I wrote a MJPG streaming server in Java for our vision system and I have a more limited C++ version of it that I ported for a personal project, but it requires Boost, which might be a little difficult to get working on the roboRIO.
I attached them both to this post, in case they might be helpful.
