Go to Post I feel that I learned more last year than any previous year because of the challenges we faced. - paldrid [more]
Unread 04-02-2016, 14:26
nlt5 nlt5 is offline
FRC #5676
nlt5 is an unknown quantity at this point
Java Paramter Type
In robot builder under commands there is a parameter section. Could someone explain when to use each type of parameter?
Thank you
Unread 04-02-2016, 19:02
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Java Paramter Type
Quick recap on command parameters:
Parameters are there so you can have one command perform multiple actions (rather than one command per action).
For example: there's a mechanism on your robot to kick boulders into the low goal, powered by a pneumatic piston and solenoid. In previous years, you would need a command for kicking and another for retracting the kicker, with their constructors looking something like this:
public KickCommand() {
    // constructor code
public RetractKickerCommand() {
    // constructor code
With parameters, you can have one command perform either action based on the parameter you give it
private final boolean m_extending;
public ControlKickerCommand(boolean extending) {
    m_extending = extending;
    // other constructor code
If a command sets one of two states, you would use a boolean parameter, like in the example above.
If a command needs a certain setpoint (like a PIDCommand), that should be a double or int
Strings don't have much use for robot control, but may see use in logging/debugging
WPILib
GRIP, RobotBuilder
Unread 05-02-2016, 08:05
FRC #5676
Thank you for taking the time to explain that.
