Go to Post Impressive. A harsh reminder of the kind of force that FRC bots exert. - Racer26 [more]
Unread 02-02-2016, 16:59
RadhikaTheFish's Avatar
RadhikaTheFish RadhikaTheFish is offline
FRC #3815
RadhikaTheFish is an unknown quantity at this point
Re-Installing LabVIEW
I'm having trouble reinstalling labview. I installed it earlier flawlessly and it worked fine it just looked a little awkward, so I programmed the robot and I was having trouble deploying the program. I tried through USB, Firewalls off, wifi off, changed IP etc. So I looked up the problem and found a conversation that said to uninstall everything and then reinstall it. So I tried it and now this comes up -
Help?
Name:	Real Time Module.png
Unread 02-02-2016, 17:59
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Re: Re-Installing LabVIEW
Make sure that you uninstall all National Instruments Software and then reinstall in the proper order as described in the getting started guide.
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
homepage: newulmrobotics.com
Unread 02-02-2016, 18:37
FRC #3815
I tried that, any other advice?
Unread 02-02-2016, 21:27
It is acting as though LabVIEW RT is being installed from the update, but the DVD hasn't been installed. If you cannot get it to install, please give the support line a call.
Greg McKaskle
Unread 04-02-2016, 15:56
FRC #3815
The Support line swears that they can't help us because "We are not the mentor" so when the mentor called the people they swore that she was not the mentor.
Unread 04-02-2016, 17:12
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
If you get that answer from the support line, ask them to talk to me. (Jeff Boellaard just in case you get someone from not on the FIRST Support Team)
https://decibel.ni.com/content/docs/DOC-46515 This link has a direct line to the support group. The phones are open 1-7PM CST.
Greg is right about what the problem appears to be. It looks like something is taking place to install the software out of order and we need to determine why.
Unread 04-02-2016, 18:33
FRC #3815
Jeff we followed your advice and recalled the customer support, we found an amazing man named John who guided us correctly instead of that other person. Thanks J & J
- Love From Radhika the Fish
Unread 05-02-2016, 09:32
Good to hear. Did he get you up and running?
If you have any idea who you talked to before, please feel free to send me a private message. Nobody on the support team should have said this. If it happened before you reached the support team, I'd want to follow up with that group to ensure another team doesn't experience this.
Unread 09-02-2016, 08:32
FRC #3815
We fixed the main problem of actually installing it, unfortunately we've come across another problem we posted in another thread. Our LabVIEW started up fine but it looks different then what everybody else is showing.
Unread 10-02-2016, 10:41
Please verify that you have installed the update and reboot after doing so.
Greg McKaskle
