Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
  #46   Spotlight this post!
Unread 30-01-2016, 09:01
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Re: pic: Shooter damaged a Boulder
We are running 4" stealth wheels that are connected 1:1 onto mini cims. The only time we damaged the ball was when we were testing, and somebody forgot to reverse the left motor. This made both motors spin the same direction. It made two small gashes in the ball but it's still usable. We have another ball we bought, but we don't want to use it until we get the final version of our shooter made. Has anybody noticed a difference in performance in a wheeled shooter from a new ball compared to an old vall? And does anybody know how often they will switch balls out in the game?
  #47   Spotlight this post!
Unread 30-01-2016, 10:25
What speed are you running it at?
  #48   Spotlight this post!
Unread 30-01-2016, 10:48
Type's Avatar
Rookie Year: 2016
To be honest, I don't really know. We have all of our electrical on a practice robot so we just plugged the motors into an old power distributor, with no motor controllers. It shoots more than far enough, just need the correct angle.
  #49   Spotlight this post!
Unread 30-01-2016, 13:29
The correct angle when you are running it straight off a fully-charged battery may not be the correct angle toward the end of an actual match when your battery is getting tired.
That's why it's important to test your prototype to see how much the correct angle is affected by voltage. If the effect is enough to be a concern, you will want to design your shooter to operate at a lower voltage (say 9 volts) and then used a closed-loop controller (PID, bang-bang, Take-Back-Half, etc) to hold the wheel speed constant as the battery gets weaker.
  #50   Spotlight this post!
Unread 30-01-2016, 17:04
Type's Avatar
Rookie Year: 2016
We were planning on getting a gear box to run at 2:1 so we could decrease the speed of the motor but still shoot the same. The mini cims have no issues with shooting the ball through a 7" opening, the motors don't really even make a noise as the ball goes through. We just need to figure if we can afford to run all the motors we want on our robot (11 total).
  #51   Spotlight this post!
Unread 30-01-2016, 19:05
2:1 would reduce your wheel speed, not your motor speed.
Did you mean to say 1:2 ?
If so, you might want to instead consider increasing your wheel diameter by 50% and reducing your motor speed appropriately.
  #52   Spotlight this post!
Unread 30-01-2016, 21:55
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Has anybody noticed a difference in performance in a wheeled shooter from a new ball compared to an old ball?
We made a second iteration of our shooter that uses 4'' colsons and no longer rips up boulders. We're running that shooter off 2 775pros. We've noticed a significant and problematic difference between a fairly new boulder and the boulder pictured here, which is now even more torn up than before. I think that this is caused by the torn up boulder losing air faster and not "pushing back" as much on the shooter wheels. I guess catapults have the edge on this problem, although they might have their own problems.
  #53   Spotlight this post!
Unread 30-01-2016, 22:13
Type's Avatar
Rookie Year: 2016
Yes, that is what I meant. So every 1 rotation of the motor, the wheel rotates twice. But it appears you understood what I was trying to say atleast. Thank you for correcting me.
  #54   Spotlight this post!
Unread 30-01-2016, 22:23
You might want to ask around for opinions from other teams who have tried that, before investing too much time in it. Just a thought.
  #55   Spotlight this post!
Unread 04-02-2016, 17:24
taytaythedj's Avatar
taytaythedj taytaythedj is offline
Head of Electronics, and Driving
AKA: Taylor
FRC #1566 (Ammoknights 1566)
Team Role: Electrical
taytaythedj is an unknown quantity at this point
I also had made a prototype that resulted in this. I used a 4 inch hi-grip wheel. Only shot it about 10 times and it is covered in bruises. We named the ball Ricardo, so out little Ricardo was in a little bit of pain.
  #56   Spotlight this post!
Unread 04-02-2016, 17:32
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
What kind of compression, gear ratio, etc. did you have for your shooter?
