Go to Post First check for any bind in the transmissions, especially chain. Next, check to see if the motors are O.K. Use code as a last resort. - Paul Copioli [more]
Unread 03-02-2016, 21:24
rpappa rpappa is offline
FRC #0340
rpappa is an unknown quantity at this point
Get image from USBCamera into an OpenCV Mat
I've successfully put opencv on the Roborio and have tested to make sure it works (will do a write up on that soon™). However, I have run into the roadblock of the fact that the USBCamera class has no apparent way to get a straight up Java Image or BufferedImage or something easy to pass to Mat.put().
Here's my code which crashes:
        USBCamera cam = new USBCamera("cam0");
        cam.openCamera();
    	cam.startCapture();
    	ByteBuffer buf = ByteBuffer.allocate(76800);
    	cam.getImageData(buf);
    	matOriginal = new Mat();
    	matOriginal.put(0, 0, buf.array());
    	Imgcodecs.imwrite("output.png", matOriginal);
The line that crashes it is probably
But I'm not sure if that matters as I don't believe I am approaching this problem the right way. Any suggestions?
Unread 04-02-2016, 05:56
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Get image from USBCamera into an OpenCV Mat
Have you treid using the VideoCapture class from the OpenCV Java libs to open the USB camera instead of the WPI USBCamera class?
Maybe something like:
VideoCapture vc = new VideoCapture();
vc.open(0); // Assuming USB camera is /dev/video0
if (vc.isOpened()) {
    vc.set(Highgui.CV_CAP_PROP_FRAME_WIDTH, width);
    vc.set(Highgui.CV_CAP_PROP_FRAME_HEIGHT, height);
If you are able to open the camera this way, you should be able to grab your OpenCV Mat objects via:
if (vc.grab()) {
    Mat img = new Mat();
    if (vc.retrieve(img)) {
        // Do what you want with the image data in the img Mat object
This is basically how we grab our OpenCV images on the driver station side (except we open the IP camera URL instead of the USB camera). If you compiled the OpenCV streaming support in your roboRIO build, I'm assuming it should work there as well.
If you then need to take the Mat and go back to a BufferedImage, here is a snippet of what we use:
	public BufferedImage toBufferedImage(Mat img) {
		if (img.type() == CvType.CV_8UC1) {
			return Conversion.cvGrayToBufferedImage(img);
		} else if (img.type() == CvType.CV_8UC3) {
			return Conversion.cvRgbToBufferedImage(img);
                return null;
Unread 04-02-2016, 06:28
FRC #0340
That looks pretty good I'll check it out tonight.
Unread 04-02-2016, 20:12
FRC #0340
Worked beautifully. Writing a white paper now.
