Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
Unread 04-02-2016, 23:45
brubakbd brubakbd is offline
FRC #5188
brubakbd is an unknown quantity at this point
Re: Navx Mxp no longer working
Alright, we got it working. Turns out it was something stupid we did. We were using a setref vi in begin and get ref where we wanted to use it. Turns out you should just alter begin and where you want to use it and make the output of the open vi an output of begin and an input of the vi you want to use it in.
Unread 08-02-2016, 08:56
Modifying the project framework (e.g. by adding an output to Begin) is usually a bad idea. Using the Refnum Set/Get functions is preferred.
The -44007 error you were getting suggests that you had spelled the name of your NavX reference differently in the two places.
Unread 08-02-2016, 14:45
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
It's too bad about the USB not working. We used that to get the navX into a good location on the robot, where we could not fit the roboRIO.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
