Go to Post Do you have to think about FIRST when you get up in the morning? - KenWittlief [more]
Unread 05-02-2016, 01:07
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Team 4276 Final Drive Prototype Testing
Final drive system testing on our practice frame, going over most of the obstacles (port door/drawbridge not in scope of this test, chival de frise mods compatibility is in work).
This was mostly a "stress test" of our pneumatic wheel drive base and evaluating how we plan to use our collector arm to assist with the obstacles. Welding our final chassis tomorrow and working on integration of our shooter and climber prototypes.
https://www.youtube.com/watch?v=gdcFMtgxuIM
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 05-02-2016, 01:23
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Team 4276 Final Drive Prototype Testing
The Drive train looks awesome.
On side note you Rock Wall looks like it might not be built to spec.
http://www.firstinspires.org/robotic...stake-and-Q612
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 05-02-2016, 09:31
seg9585's Avatar
AKA: Eric
We are aware of the changes to the rock wall dimensions but have not made any modifications to our field construction yet to accommodate. Based on our chassis height and wheel spacing we don't believe the larger width or height will be an issue (the increased width will actually help a bit). Thanks for pointing this out as a reminder though!
My FIRST legacy:
Unread 05-02-2016, 09:54
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Looks good! I like how your intake was used to help you over the ramparts.
I also love seeing it drive slowly over, Gives a much better sense of what is happening.
Quick question: What is your wheel psi? Have you played around with that number at all yet?
We are hoping to have something driving tomorrow so its something I'm currently thinking about! lol
Unread 05-02-2016, 10:21
seg9585's Avatar
AKA: Eric
We use the arm as leverage for the ramparts and some of the other obstacles to position our CG. The arm is actually strong enough to pick up the middle wheels if we got stuck anywhere (another part of this test). We drove over the obstacles at both slow speeds and fast speeds to look at the dynamics of the wheels and impact angles after crossing (especially landing after the rock wall).
Great question about the pneumatic wheel pressure -- we first tested with pressure maximized at the tire's pressure rating (32psi?) and the robot was very bouncy (you can see that here). For the tests in the original thread, we lowered the pressure to about 10psi and below which gives us great dampening and more surface area to get traction. We are still trying to decide on our final pressure but we know it will be low.
My FIRST legacy:
Unread 05-02-2016, 10:27
FRC #1360
I can assume that's at full weight as well? It's nice to see that you tested it so many different ways!
Exactly how to learn whats best for you bot!
Thanks for the response!
Unread 05-02-2016, 11:54
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Robot weight as tested was about 85lb. Thats about 15 under total expected. We had a shooter mechanism "on" the robot but not powered, and our scaling mechanism was on a table someplace.
BUT, that 85lb robot can push with 233lb of force
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 05-02-2016, 11:58
FRC #1360
I am looking more at how the weight affects its bounce with regards to wheel pressure.
Is that 85lbs including battery?
Unread 05-02-2016, 12:26
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
No battery.
Also, in the "bouncy" video you can see we took the arm off due to some spontaneous dismantling. That made the robot lighter still.
The final prototype video at the top has some pretty low PSI wheels. You can see that the center wheel looks almost flat on the robot's left side.
We're eager to test this on something closer to the actual field. Linoleum and plywood doesn't substitute for carpet, HDPE, and aluminum.
