Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Unread 22-01-2016, 10:27
jdude999 jdude999 is offline
FRC #3044
jdude999 is an unknown quantity at this point
Tables?
I was just wondering if you could create tables using you app?
Unread 22-01-2016, 12:50
jkoritzinsky jkoritzinsky is offline
AKA: Jeremy Koritzinsky
FRC #4786 (Nicolet F.E.A.R.)
jkoritzinsky will become famous soon enoughjkoritzinsky will become famous soon enough
Re: Tables?
You cannot create tables that will show up on the mobile devices. If you mean outputting tables, the server outputs a zip with csv files that can be imported into any database.
Nicolet F.E.A.R. (Team 4786) - Aerial Assist - Programming Manager
Nicolet F.E.A.R. (Team 4786) - 2015+ - Junior Mentor
SuperScouter for FRC Developer
Unread 22-01-2016, 18:45
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
Re: SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
This is pretty awesome. Suggesting it to the scouting team for evaluation.
To make data entry quicker, could there be a data entry method that is a simple count up or count down toggle? This way I only have to tap a + button when someone scores a boulder for example, rather than moving a slider or manually typing it in.
Unread 22-01-2016, 22:48
I was thinking about that. I'll put it in the feature backlog.
Unread 23-01-2016, 22:32
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of lightsnoman is a glorious beacon of light
this is not my wheelhouse. i created schemas got them onto my phone but am unable to send data from my phone back to the computer. tried using the same http as when i sent it to phone . what am i doing wrong??
thanks
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 24-01-2016, 22:11
thanks
Is the HTTP Server still on? What is the specific error that you get when sending?
Have you tried using the QR scanner instead and seeing if that works?
Unread 26-01-2016, 00:14
snoman's Avatar
Got it to upload back to computer. How do I import to excel? Thanks
Unread 26-01-2016, 00:50
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Select the Export Data from Regional on the home screen. That will download a zip folder with CSV files with your uploaded data in it. Just open that in Excel
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
Unread 26-01-2016, 15:54
Orophine Orophine is offline
None #4967
Orophine is an unknown quantity at this point
when i create a scheme it does not let me save it CTRL+S does not work and both save buttons that i could find in the interface were not working either.
how do i save my scheme or am i missing a step that i must do before i can save?
Unread 26-01-2016, 16:46
Dancing Drive Coach
What I've found (Jeremy correct me if I'm wrong), if an option within a schema doesn't have an ID, it won't let you save the schema. (This might be nice to have a warning about)
Unread 27-01-2016, 01:05
You are correct. I will add that to the documentation that I am currently working on. I'm pretty busy right now with the start of the semester, but hopefully I'll be able to get it out soon.
Unread 05-02-2016, 01:33
alexpell00 alexpell00 is offline
FRC #2972
alexpell00 is an unknown quantity at this point
Hello,
I was thinking of making my own scouting app and wanted to know if people liked SuperScouter. If people like it then it might just be worth stuck with it.
Unread 05-02-2016, 02:33
NinjaMunkeeNao's Avatar
NinjaMunkeeNao NinjaMunkeeNao is offline
Programming Padawan
AKA: Naomi-Christina
FRC #2395 (The Ninja Munkees)
Rookie Year: 2016
NinjaMunkeeNao is an unknown quantity at this point
This is awesome! Last year even though I wasn't on my team I helped with scouting (I'm a sibling of a senior team member and attended every single competition), and it definitely isn't the funnest thing on the planet, so I'm really glad to see this coming out. It looks really cool!
A quick question: do you know when the app will be available for download on the App Store?
Unread 05-02-2016, 02:40
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This seems like a really great system. The only thing is that the app keeps crashing on all of my devices (tried on a Galaxy S6, Nexus 4, Nexus 5, and Nexus 7). I made a schema and downloaded it to my device but when I tap 'Enter Data' and select the schema, the app crashes.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 05-02-2016, 08:30
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Do you have any specific plans/roadmap for when newer types of Schema will be added?
