Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 05-02-2016, 08:04
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Questions about pneumatic wheel legality
Originally Posted by Sperkowsky View Post
We are using versaframe to fix this same issue on our bot. Essentially we just have a little U of versaframe attached with Gussets to each corner of the drive train. We had a couple of freshman make it and it looks good.
Can you share a picture? As an RI, I would worry that these are not long enough based on the description to support an 8" bumper, but I would have to see it. There are versions of interpretations of you described assembly (such as it is) that are legal, but also some that are not.
Originally Posted by longilive View Post
Put something solid over (above) the wheels and have it stick out barely past the wheels (so you can use it to define the frame perimeter). You can use this as a bumper mount as well.
Same comment. That would work if the structure is wide enough. Then they would need to be sure their overall frame perimeter is less than 120 as they would have to extend it at least 4" (1" in each corner) based on the picture
