Go to Post Yes, this year's championships could be decided by cheesecake. - MrJohnston [more]
Unread 05-02-2016, 15:24
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Re: pic: Custom encoder mount for Mini CIM/CIM
Originally Posted by Peyton Yeung View Post
Does that still leave you much space for pinion gear mounting inside a gear box? Very similar to this one.
I'm not sure, it might not work for some pinion to gearbox applications, but it works well for an 8mm inside diameter keyed shaft (or equivalent shaft adapter).
I hadn't seen the one in the link before! Here I thought we had a novel idea!
