Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 02-02-2016, 15:11
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Re: Playing well with others while scaling the tower
Originally Posted by Jared Russell View Post
How often did 3 robots on an alliance all hang in 2010?
That was a much simpler game (fewer things to do/less tradeoffs to make) and hanging/suspending was the single most valuable robot action, points wise. The rules on robot expansion were more lenient (84" diameter cylinder during the endgame), there were 4 sides/corners for teams to find space, and there were multiple options for hanging (vertical or horizontal bars).
I would love to see all 3 robots scale the tower regularly, but I think it will fall into the "there's a Chief Delphi post every time it happens" category of rarity.
In 2010, there weren't nearly as many teams as we have now, there were not nearly as many gearbox/motor/mechanism COTS options available, and there were not as many web based/otherwise easily accessible design and knowledge resources. FIRST is growing, and with it the average quality of teams. That's the nature, and arguably the goal, of any competition; improvement.
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 02-02-2016, 16:44
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
I have a different but related questions. With Rule G28, will offensive teams chase around defending bots in the Courtyard to get credit for scaling the castle?
Unread 02-02-2016, 18:16
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Originally Posted by ToddF View Post
3) Plan to be the only robot on your alliance to scale. This will limit your chances to be on a winning alliance.
I'm publicizing this issue because we want to be on alliances with multiple climbing robots, and putting it out there makes it more likely this will happen.
I've been aware of this situation, but what leads you to believe this will be a huge and recurring issue for your team in particular? Curious to see when 2363 expects to have two alliance partners that will be climbing with them.
Unread 02-02-2016, 19:25
If it's obvious that they're chasing, it's more likely to be a G11 than a G28. If the D-bot is in their way in the path to the tower and doesn't get out, however...
I suspect that D-bots will start diving for the Secret Passage or Group C defenses at some point around 25 seconds left in the match. Maybe the Low Bar.
Unread 02-02-2016, 20:39
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
All of these points are legit. This year will be more like 2013, the year that no one climbed above the first rung.
Remember why you're doing this.
Unread 03-02-2016, 00:09
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
For what it's worth, of the final 8 alliances (division finalist and winners), half had a robot that climbed above the first rung (two alliances actually had two). There were a lot of really good robots that won a lot of events/matches by climbing in 2013. I actually think this year will be similar to 2013 in that there will be several viable strategies or alliance compositions that will win.
Unread 03-02-2016, 07:39
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Well, in a perfect world...
I've been advocating that the best robot design for the effort is one that 1) traverses defenses 2) herds balls into the low goal 3) hangs. Even for low resource teams, this is very doable, if they don't waste resources on a high goal shooter.
Do I really expect to be a part of alliance with 3 hangers? Realistically, probably not in districts. Maybe at district championships. Much higher chance at World Championships.
But, if we can help teams get there, so much the better.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 03-02-2016, 10:00
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
It almost may be useful to have 2 robots that can scale and one that can not for each alliance. If an alliance had two that could scale, they could take the outer sides of tower, and the non-scaling robot could sit on the center. I know this thread isn't about strategy for the game (besides figuring out to hang) but my team actually believes we could get more points for shooting during those lasts 20 seconds than the 15 for scaling, then we could still sit on the base, helping the alliance get the extra points for conquering the tower. Removing the climbing mechanism will make the robot lighter, and allow us to spend more time working on other aspects of the robot.
Unread 05-02-2016, 15:07
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Two words:
Stacked Scale
#701Odin2012
Unread 05-02-2016, 15:24
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Originally Posted by bEdhEd View Post
Two words:
Stacked Scale
#701Odin2012
You do realize that being in contact with a unique rung is a requirement for scaling? Supporting another robot in the same third of the tower does not get that robot SCALE points. If two robots are in contact with the same rung, neither robot gets SCALE points.
Unread 05-02-2016, 15:25
Jared Russell's Avatar
Taking a year (mostly) off
Two words:
Stacked Scale
#701Odin2012
Two words:
unique RUNG
as in:
Originally Posted by Stronghold Manual
SCALE
an act performed by a ROBOT, such that at the conclusion of the MATCH, it is in
contact with a unique RUNG, and has all of its BUMPERS fully above the height of the
low GOALS.
Unread 05-02-2016, 15:52
bEdhEd's Avatar
It's a joke, guys.
However, now I'm entertaining the thought of a stacked scale where the carried robot has an extension that touches the adjacent rung for the sake of the "contact" part of the definition while all the way up. I'll have to look closely at the manual again to check the legality of this. If anyone sees a problem with this, go a head and point it out.
For the record, stacked scaling is not part of our design and never has been.
Edit: I've looked through that section again, and it seems like having a robot stacked on a scaler while the carried robot contacts another unique rung may be a legal strategy. I can't think of any interpretation of the scaling definition to include being fully supported by the rung, and neither does a scaling robot have to stay in front of the tower face to which the rung is attached, as long as it contacts one rung and one rung only with the bumpers at scaling height. Another requirement is that the extension stays within the 15 inch perimeter limit.
I don't recall reading a rule with regards to allied robots breaking their respective frame perimeter planes for a stack configuration. If someone could cite that rule, that would be great. Maybe a stacked scale isn't all that impossible after all?
Unread 05-02-2016, 17:08
Racer26 Racer26 is offline
This was precisely the reason that 1114 initially shocked everyone in 2013 by not having a floor pickup in favour of having a 30pt climber.
They knew that:
a) They were Pre-Qualified as an Einstein team in 2012, and as such didn't need to win a regional to qualify
b) 7 disc autos were a thing that only one team on an alliance could do, and having 2 7disc autos on your alliance was of no benefit.
c) 7 disc autos would be fairly common among top seeded teams at CMP
d) Reliable, fast, 30pt climbers would be rare, and thus of high value to a 7disc auto alliance captain.
Their plan worked, too. They were the #1 alliance captain's first pick. They just ran into some bad luck between there and Einstein.
Unread 05-02-2016, 17:16
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
They knew that:
How do you know what 1114 was thinking? If you are going to make points like this I would really like to see a source for this information. Because I don't think you really know what they were actually thinking.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 05-02-2016, 17:51
I know this because I personally spoke to several members of their team about their design decisions. A conversation I started because it struck me as odd at the time that they would choose to do something that would make it difficult for them to seed #1.
