Go to Post I applaud teams that make signs of all kinds - giant numbers, large banners, humongous heads. It's all good. - Ryan Dognaux [more]
Unread 05-02-2016, 17:24
Trinitrotoluene's Avatar
Trinitrotoluene Trinitrotoluene is offline
FRC #3102 (Nevis Tech-No-Tigers)
Trinitrotoluene is an unknown quantity at this point
Read air tank pressure to dashboard?
Our team is using pneumatics this year, and we'd like to be able to view how much pressure is in our air tanks from the FRC Dashboard. We are using LabVIEW.
I have a complete pneumatic system hooked up. When running a self-test on the PCM, it registers that "Pressure is full" when the compressor is shut off, so it obviously knows what the pressure is. Is there any way I can get this value into the dashboard?
Unread 05-02-2016, 17:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Read air tank pressure to dashboard?
You need a separate pressure transducer in order to read pressure. The switch just measures whether a certain pressure is reached, not what the exact pressure is.
Unread 05-02-2016, 17:28
Thanks! So something like this?
Unread 05-02-2016, 17:29
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Hi Wyatt,
The control system doesn't have a native way to read pressure, however we sell an analog pressure sensor that you can connect to one of your analog inputs. You can then calculate and display your system pressure on the dashboard.
Take a look at the REV Analog Pressure Sensor and let me know if you have any questions!
Edit: Looks like you found it!
-David
David Yanoshak
Co-founder REV Robotics | www.revrobotics.com
Unread 05-02-2016, 17:32
Do you know how this would be programmed in LabVIEW?
Unread 05-02-2016, 17:56
cgmv123's Avatar
AKA: Max Vrany
It's an analog input. The voltage read by the analog input linearly corresponds to the pressure of the system.
Unread 05-02-2016, 18:02
Thanks for your help, guys!
