Go to Post ... you know you are a nerd when you want safety glasses for your birthday! :P - Ashley Christine [more]
Unread 05-02-2016, 19:56
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: 7075 sheet metal
You never mentioned what temper the 7075 is. Might make a difference...
I found this bend radius table that shows workable bend radii for 7075 sheet products.
http://www.americanmachinetools.com/bend_radius.htm
We have found it easy to hit controlled bend radii on our pan and box brake by making forms out of very soft aluminum to put over the fingers on the brake. You could do the same, or use a press brake with a die of the appropriate radius.
