Go to Post We’ve been chasing perfection since 2003 in the hopes of catching excellence. - Karthik [more]
Unread 02-05-2016, 07:57 PM
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
best way to temp mount battery
What the best way to temporary mount a battery? Just need to mount it for a couple of trial runs (we are not close to deciding the final battery position).
Unread 02-05-2016, 08:00 PM
Re: best way to temp mount battery
Securely...
We used some aluminum angle to support the base, tied it down with string, and added a pool noodle section to (try to) keep it from moving. Before the string, we'd tried duct tape and the battery went flying.
Unread 02-06-2016, 02:56 AM
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Ziptied surgical tubing bands or bungee tiedown work well.
Unread 02-06-2016, 08:55 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not knowing what your robot looks like in the area you intend to mount it, there's really no way to say what would work well. You need to check all 29 directions it could move to make sure it can't move that way. 26 directions are translations:
  • toward each of the 6 faces of the battery
  • toward each of the 8 corners
  • toward each of the 12 edges
And the other three are rotations: roll, pitch, yaw.
If you're using the KoP chassis and have enough room inside, a battery fits snugly inside the front or rear plate. That will knock out roll, pitch, and five more directions by itself, and give support for several of the others.
Unread 02-06-2016, 09:11 AM
Chris is me's Avatar
AKA: Pinecone
29 degrees of freedom is ridiculous - for example, there is no way you can secure all 6 faces of the battery OR all 8 corners while leaving an edge free to translate. In reality, as with all solid objects in 3D space, there are 6 degrees of freedom - translation in X / Y / Z and roll / pitch / yaw. If your battery is fully constrained in all 6 of these degrees of freedom, it can't move regardless of whether or not you can see a corner of the battery.
As to answer the OP's question - you basically want to secure the battery as well as you would secure it on the final robot, even temporarily, since you're likely to be flying across obstacles and whatnot. Some aluminum angle on four sides with a strap across the top is an easy temporary way to do it. Don't use tape. Try to take advantage of existing geometry on your robot (ie the side of the chassis, etc) if you can. Do secure the top of the battery as you'll be jumping over some rough obstacles and it could jostle loose.
Unread 02-06-2016, 09:13 AM
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Large zipties, one of the AndyMark battery mounting kits, or a tie-down kit will work for temporary mounting purposes.
But make sure temporary doesn't turn into permanent. Like Chris said, start designing a permanent solution to take use of existing robot geometry. You don't want to go out on the field and have your season ruined by a loose battery
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
Unread 02-06-2016, 09:19 AM
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
I'm unsure what you're trying to get at. There are 6 degrees of freedom for any given object. Translation in X, Y, and Z. Rotation in X, Y, and Z. Whether you're talking about a battery, wheel, shaft, gear, arm, etc. those are what you need to think about.
For your battery, if you were to screw together a rectangular wooden frame that the battery lies in, you would take care of translation in X and Y, and rotation in Z. Large zip ties or a nice Velcro strap and you can hold it down to eliminate translation in Z, and rotation in X and Y. Just an example.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 02-07-2016, 12:30 AM
Nate Laverdure's Avatar
FRC #2363
At risk of piling on, here's an excerpt from an email I wrote to my team once.
To better understand "degrees of freedom," consider a fish flying through the air:
The fish is free to translate along each of the three principal axes of our 3-D world: X, Y, and Z. That's 3 DOFs. The fish is also free to rotate about each of these axes as well. That's another 3 DOFs, for 6 total. All solid objects floating through space, like the fish is doing, have exactly 6 degrees of freedom.
Secure your battery well, or it will fly like a fish.
Unread 02-07-2016, 12:47 AM
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
It takes time, but in order to do this construct a frame that secures the battery and then secure it to the frame with bolts.
It doesn't matter the materials you build the battery restraint from (wood, steel, aluminum, polycarb, etc.) - it is a VERY bad idea to place the battery without it being constrained. You do not want the battery to come loose for obvious reasons: damage to the battery (costly and messy), and damage to your robot.
Build a battery frame that you can use now and in subsequent years. Take the time now and save time later.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 02-07-2016, 01:51 AM
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
We made a frame in the middle of our chassis out of angle aluminum for testing, and then used one of these to anchor the battery down with Velcro. It worked quite well, and I would say that for testing the battery base is probably unnecessary.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 02-07-2016, 03:23 AM
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Whatever you do, don't let this happen:
https://youtu.be/fJyqnlZHs6w
Students got a little bit too excited about a new drive maneuver they discovered...
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 02-07-2016, 08:16 AM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
http://www.andymark.com/product-p/am-0477.htm
We have stockpiled a few of these over the years. They work very well for temporary or permanent mounts.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 02-07-2016, 02:45 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
While there are only six actual degrees of freedom, looking only at motion directly along each one is not enough. You need to consider all of the diagonal possibilities as well. I recall seeing a documentary about a building in NYC that had some cantilevered sections. Engineers wind-tunnel tested models for north, south, east, and west winds. It passed, and was built. After it was built, it behaved as expected in north, south, east, and west winds. When the first nor'easter blew in, the building swayed dangerously, and they had to retrofit structure into a working office building by night to prevent a "domino effect" of falling buildings. When it comes to safety, consider the "in between" cases.
Unread 02-07-2016, 02:55 PM
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
That definitely would ruin your season. The blue box of G1 says you can't drag your battery or you won't pass inspection.
Unread 02-08-2016, 05:19 AM
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Remember that the battery is a 8lb box of acid, death and lead. When in doubt mount it more solidly then you think you need.
