Go to Post You know you have bad field problems if both Dean and Woodie come out to try to fix them... :) - tim_reiher [more]
Unread 01-02-2016, 13:46
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Using the driver station laptop as a controller
We are playing around with the idea of having our drive team manipulator student use the driver station laptop keyboard and mouse as controllers during matches. Here is more detail on we are planning on doing that.
https://docs.google.com/presentation...it?usp=sharing
  • Have teams ever used the driver station laptop itself as a controller during matches?
  • What issues did you run into?
  • How well did it work?
  • Did you run into issues where the student has to keep looking down?
Presumably the buttons on the keyboard could be used while looking at the field in all instances except for shooting.
Thanks for the feedback.
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 03-02-2016, 00:49
spat's Avatar
spat spat is offline
QDriverStation Developer
AKA: Alex Spataru
FRC #3794 (WinT)
spat is on a distinguished road
Re: Using the driver station laptop as a controller
Well, our team uses the keyboard as a controller during public presentations with the robot (using the QDriverStation) and we never had problems (e.g. unintentional movement, dead-band, etc). In fact, most of our drivers (including myself) prefer to move the robot with the keyboard since it allows us to make more precise movements.
However, unless you get a special application or driver to work with the FRC Driver Station, I seriously doubt that the FTA would let you use the QDriverStation in an official match.
When Henry Ford made cheap, reliable cars people said, 'Nah, what's wrong with a horse?' That was a huge bet he made, and it worked. - Elon Musk
Unread 03-02-2016, 07:35
The official DS has no built-in support for the keyboard, but there is no rule or technical reason that you cannot read the keyboard and send it to the robot using the network functions. At least not that I know of.
Greg McKaskle
Unread 05-02-2016, 07:15
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
If we hooked up a USB keyboard and mouse tot he keyboard would that be easier to work with?
crazy engineer
helping team 1389
Unread 05-02-2016, 07:45
For most APIs, they OS will blend them all together into one. The VIs in LV will tell you which joystick button is pressed, but the keyboard stuff can't differentiate, as the system owns all keyboards. I think that RawInput API will tell you which, but I haven't done it, so can't be sure.
Greg McKaskle
Unread 06-02-2016, 08:44
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
How about something like this? http://www.saitek.com/uk/prod/farmside.html
It would connect via USB but be more of a control panel that could replace the keyboard keys.
crazy engineer
helping team 1389
