Go to Post You might even learn something! - Tom Bottiglieri [more]
Unread 06-02-2016, 10:24
2386programming 2386programming is offline
FRC #2386 (Trojans)
2386programming is an unknown quantity at this point
Talon srx programming
How would I program a talon srx to ramp our speed? Also how to I program it in the begin vi? We are using labview
Unread 06-02-2016, 11:37
ItsAMeNick ItsAMeNick is offline
FRC #4557
ItsAMeNick is an unknown quantity at this point
Re: Talon srx programming
The easiest way would be to use an "x squared" input for your joystick.
It would give you a large range control. If you think this would work I could provide more information.
Unread 06-02-2016, 12:33
That just changes the joystick sensitivity. It wouldn't ramp the speed.
See Section 6 "Setting the Ramp Rate" in the Talon SRX Software Reference Manual.
EDIT: if you aren't using CAN to command the SRX, you can do the ramping in your roboRIO code.
