Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Unread 06-02-2016, 12:33
Re: Talon srx programming
Originally Posted by ItsAMeNick View Post
The easiest way would be to use an "x squared" input for your joystick.
That just changes the joystick sensitivity. It wouldn't ramp the speed.
See Section 6 "Setting the Ramp Rate" in the Talon SRX Software Reference Manual.
EDIT: if you aren't using CAN to command the SRX, you can do the ramping in your roboRIO code.
