Go to Post A problematic dynamic and culture becomes apparent when failure persists for such a duration and reoccurs so frequently that students begin to accept it as the norm, and never learn the proper way to do things. - sanddrag [more]
Unread 06-02-2016, 13:58
ChrisM2346's Avatar
ChrisM2346 ChrisM2346 is offline
A Box Full of Pepe
AKA: Chris Mitchell
FRC #2346 (Celtechs)
ChrisM2346 is an unknown quantity at this point
Questions Regarding Motors and Buttons
Hello! I'm having a bit of trouble with getting two motors (not used for driving) to be controlled with two buttons: one to move them clockwise, another button for counter-clockwise.
The two motors are Talon SRs, and they're both wired to separate PWM channels. Every time I enable the robot on the Driver Station, I'm confronted with errors 91 and -44007.
Any ideas? How should I wire the motors in Teleop mode in Labview?
Unread 06-02-2016, 14:04
ChrisM2346's Avatar
A Box Full of Pepe
AKA: Chris Mitchell
Re: Questions Regarding Motors and Buttons
Here's how I tried to do it in Teleop: https://www.dropbox.com/s/dvoa9qtq8o...61304.jpg?dl=0
Unread 06-02-2016, 21:44
To get more detail on most error codes, you can right click and choose Explain Error. Or you can go to the Help menu >> Explain Error and type in the #. It will tell you that -44007 means that the refnum name doesn't exist. This likely means that the string is spelled differently in Begin and TelelOp. It is case sensitive as well.
Greg McKaskle
