Rhino track failier?
My team purchased the Rhino Tracks from Andy-Mark this year, but after driving with them, the pulleys (am-3298) have started to fall apart. The plastic is chipping around the bearing. Is anyone else having similar issues?
Re: Rhino track failier?
sorry pic in not working
Try attaching the image to the post as an attachment, or linking it differently.
[IMG]blob:https%3A//mail.google.com/82aaea0c-d18f-40c0-8001-74d3ed496baf[/IMG]
copy this link into google without the [IMG]
Try again. Link does not work at all.
#7
Upload your image to imgur.com and provide the link here. We're not logged into your Google account, so we can't see images in your email.
#8
#9
there it is, thanks
#10
Did you use locate when you assembled them? Because that looks. Exactly. Like. When a student used locate on our wheels. One year some got. On the plastic and the locktite eats. A. Component of the plastic. And they fall. Apart
#11
We just had the same breakage today. We are checking for more signs of weakness. Did you have more than one break??
#12
these wheels where assembled with 6 bolts, 3 per side. we followed the manufactures construction. I think that it may come from a combination of over-tightening of the the track, or the force of the robot slamming into the ground after crossing a defense. We have broken 5 of these wheels so far. Is this happening for anyone else?
-thank you for any info you can give |
#13
We haven't done a lot of defense crossing yet. Today we were code testing when we found the broken piece. We weren't even sure where it came from until I read your question. Keep us posted
![]() *update we found cracks on several wheels, some are in advanced stages but not broken yet. placement on the track was not a factor. we also do not believe it is a tension issue. Last edited by callmecairo : 02-06-2016 at 04:08 PM. |
#14
Some plastics react badly (called crazing) to superglues (CAs in particular) and Loctite. The bearings should be a slight press-fit into those pullys and should not need any glue. If they are a little loose, use a fender washer and spacer to keep them there. |
#15
no adhesives, only bolts. this is a very dense plastic, when it breaks it cracks it is a lot like obsidian, it forms very shiny surfaces
