Go to Post So let me get this straight. We'll have 6 hours to re-build an entirely new robot that took us 6 weeks originally to make. - [more]
Unread 06-02-2016, 14:46
jayjay jayjay is offline
jayjay is an unknown quantity at this point
Any help appreciated
I have written a simple java program to test our 2016 bot. I have update the firmware, image and jre on our 2015 roborio, and updated to the latest version of Eclipse. Our drive consists of four motors – one Talon controller with a y-splitter controls the two left motors, and another Talon with a y-splitter controls the two right motors.
The bot works with a simple arcade drive coded in the teleop method. When I add the setInvertedMotors code (which worked last year), I get “no code” on the bot, a red comm light on the roborio, and the following error:
ERROR Unhandled exception: java.lang.NullPointerException at [edu.wpi.first.wpilibj.RobotDrive.setInvertedMotor( RobotDrive.java:703), org.usfirst.frc.team4951.robot.Robot.robotInit(Rob ot.java:38), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]
Here is my code:
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.RobotDrive.MotorType;
public class Robot extends IterativeRobot {
    final String defaultAuto = "Default";
    final String customAuto = "My Auto";
    String autoSelected;
    SendableChooser chooser;
    RobotDrive myDrive;
    Joystick stick0, stick1;
    public void robotInit() {
        chooser = new SendableChooser();
        chooser.addDefault("Default Auto", defaultAuto);
        chooser.addObject("My Auto", customAuto);
        SmartDashboard.putData("Auto choices", chooser);
        myDrive = new RobotDrive(0,1); // 0 = left, 1 = right
        stick0 = new Joystick(0);
        stick1 = new Joystick(1);
        myDrive.setInvertedMotor(MotorType.kFrontLeft, true);
        myDrive.setInvertedMotor(MotorType.kRearLeft, true);
    public void autonomousInit() {
    	//autoSelected = (String) chooser.getSelected();
//		autoSelected = Smart;Dashboard.getString("Auto Selector", defaultAuto);
		//System.out.println("Auto selected: " + autoSelected);
    public void autonomousPeriodic() {
    	switch(autoSelected) {
    	case customAuto:
        //Put custom auto code here
            break;
    	case defaultAuto:
    	default:
    	//Put default auto code here
            break;
    public void teleopPeriodic() {
        myDrive.arcadeDrive(stick0);
    public void testPeriodic() {
Any help with the error would be appreciated. Thanks.
