Go to Post CAD pictures are cool, but hardware in hand is cooler. :) - ajlapp [more]
Unread 06-02-2016, 15:30
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
Re: Shooter Aiming with Tables
@Turing'sEgo Thank you!
@Ether That is my plan. Sometime this week we'll be able to begin testing with our actual shooter.
I am not actually sure how to write code to reference a lookup table. I was going to start looking for related Labview documentation. If anyone has a link they can post here I'd appreciate it.
Thanks,
Benjamin
Unread 06-02-2016, 16:56
Here is an example of lookup tables from the NI developer community:
This one is good for use with a spreadsheet.
https://decibel.ni.com/content/docs/DOC-14653
It may need a bit of updating to LabVIEW 2015 (what we're using for FRC 2016).
A little less complex is something like Interpolate 1D Array found in the palettes under Programming->Array
or maybe Search Ordered Table.vi found under Mathematics->Interpolation & Extrapolation
Unread 06-02-2016, 21:54
Mark beat me to it, but I generally use the Interpolate 1D function.
Your lookup table is an array of number. They can be typed into a constant or be read from a file as a 1D array. Be sure to run the subVI and enter some values by hand and ensure that the output values make sense.
Greg McKaskle
Unread 13-02-2016, 13:01
FRC #4206
So I'm looking into using the Interpolate 1D Array. How can I convert my spreadsheet into the 'array of numbers or points' that the function requires? Also, should I store the file in the project folder?
Thanks.
