Go to Post The secret to this whole thing is that it's the robot that builds the team. - JohnBoucher [more]
Unread 06-02-2016, 15:38
tkdberger's Avatar
tkdberger tkdberger is offline
SPAAACE
AKA: Hugh Mungous
FRC #3494 (Quadrangles)
Rookie Year: 2016
tkdberger is an unknown quantity at this point
Lightbulb Logical Auto?
Anyone know if you can safely do logic in Autonomous mode?
Something like
while(condition) {
    new SomeCommand;
(assuming you are doing a command based robot, not sure how it works for others)
Unread 06-02-2016, 15:41
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Logical Auto?
Careful with the while command. Better to use autonomusperodic
Unread 06-02-2016, 15:43
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
Question Re: Logical Auto?
Could you explain a bit more? This is my first time doing programming.
Unread 06-02-2016, 15:48
Re: Logical Auto?
There is a concept of a "heartbeat". I believe it goes something like this: if your code does not return from periodic after a certain amount of time, the system presumes your code has crashed and disables all motors.
While loop can take too long to execute and trigger the fail safe.
Unread 06-02-2016, 15:51
tkdberger's Avatar
SPAAACE
AKA: Hugh Mungous
Rookie Year: 2016
Smile Re: Logical Auto?
Alright. Guess I'm researching AutonomousPeriodic then.
Unread 07-02-2016, 15:42
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Logical Auto?
Autonomous periodic just runs periodically (something like every 20 ms?) throughout autonomous. In Java, if you check out the code they literally just loop through the code in autonomous periodic. Autonomous init is just the first iteration of that loop. I'm not entirely sure but I'm willing to wager that C++ works using the same logic.
Unread 08-02-2016, 20:01
MaikeruKonare's Avatar
MaikeruKonare MaikeruKonare is offline
Programming Division Captain
AKA: Michael Conard
FRC #4237 (Team Lance-a-Bot)
MaikeruKonare is an unknown quantity at this point
Re: Logical Auto?
We don't use command based, but all while loops in any of our three main functions (Teleop, Autonomous, or Test) look like this:
while(IsOperatorControl() && IsEnabled()) {}
while(IsAutonomous() && IsEnabled()) {}
This prevents any loops going longer than they should, such as when the mode changes or the robot becoming disabled.
Hope that helps.
